keyless entry transmitters different than OEM alarm transmitters?
Old Aug 12, 2002 | 09:36 AM
STL's Avatar
STL
Default keyless entry transmitters different than OEM alarm transmitters?
So does the OEM alarm come with its own additional transmitters? If so, are these different than the keyless entry ones (that come with all S2000s)? That's what I gathered from a search, but I wanted to confirm it.
Old Aug 12, 2002 | 09:51 AM
andrewewing's Avatar
Yes, it comes with it's own transmitters. You heard correctly
Old Aug 12, 2002 | 12:57 PM
Dookie's Avatar
Technically, they're different, but are nearly identical. The "Trunk" button on the door lock remote is labeled "Option" on the alarm remote. Otherwise, they are the same. I'm not sure if they are interchangable.
Old Aug 12, 2002 | 01:19 PM
PLYRS 3's Avatar
so, in other words, if you DO NOT get the alarm, you still get keyless entry with a remote that looks identical to the alarm remote, expect that the trunk button actually has a picture of a trunk??
if you get the alarm, the remote "operates" both the alarm and the keyless functions?
also, i assume there is no panic button on the "just keyless" remote??
so simple, yet so confusing
ps. i thought the alarm was standard - maybe here in canada it is - that's why this question never occurred to me....
Old Aug 12, 2002 | 01:20 PM
lucid's Avatar
Yes like dookie said... The remote from the Keyless OEM will still work when you have the alarm but will not unarm or arm it.
Old Aug 12, 2002 | 01:22 PM
PLYRS 3's Avatar
so, do you need both/two??
i have the OE alarm, but only one remote that operates the keyless and arms/disarms the alarm.
Old Aug 12, 2002 | 01:25 PM
Silver Bullet's Avatar
They look very similar but the do function slightly different.
As Dookie stated, the "Trunk" button on the original keyfobs are labelled "Option" on the keyfobs that come with the Honda alarm system. The "Option" button, in combination with one of the other buttons, allows you to enable and disable an audible alert when you lock/unlock the car doors (i.e. the car's horn sounds or the siren, if installed, chirps in addition to the lights flashing). The "Option" button also functions to open the trunk just like the original keyfobs.
If your car has the Honda alarm system, you can still use the original keyfobs. They will still function to unlock/lock the doors and trunk, however, they will not disable the alarm. This makes them useless.
The control unit for the alarm system is programmble and can accept codes from multiple keyfobs so it may be possible to program the control unit to work with the original keyfobs. Four keyfobs is an overkill though. I just ues the keyfobs that came with the alarm system.
Old Aug 12, 2002 | 01:30 PM
PLYRS 3's Avatar
[QUOTE]Originally posted by Silver Bullet
[B]Four keyfobs is an overkill though.
red 2000 s2k
Oct 9, 2009 01:33 PM
Verik
Jan 22, 2008 06:14 AM
NoRawkus305
Sep 15, 2007 04:12 PM
MadeInTaiwan
Jan 16, 2007 09:48 AM
DVSwetwilly
Aug 26, 2004 05:31 PM
