launch
Old May 12, 2007 | 03:33 PM
itS2Klasic's Avatar
Default launch
I kno different people have different theory about launching there cars at the drag strip. since this is my first rwd car i have no idea what rpm should i be at when iam launching it . So if u guy can give me a couple of ideas and what works best for u guys that would be great thanks...............ps iam not a 1/4 mile whore just wanted to kno
Old May 12, 2007 | 03:36 PM
afwfjustin's Avatar
6k give or take and sidestep the clutch. Make sure your tires spin. After you launch, feather the throttle so that you stay above VTEC and wait for the tires to hook up. As soon as they do, floor it.
Oh, and prepare for a bunch of wankers to tell you that the s2000 wasn't meant for drag racing.
Old May 12, 2007 | 03:58 PM
GOS2K007's Avatar
This sounds about right.
By the way, the S was not made for drag dracing.
Old May 12, 2007 | 04:46 PM
KnowledgeIsPower's Avatar
i agree. the s was not made for drag racing. but just to reiderate (sp?).. do NOT feather the clutch or you will break your differential. side step it.
Old May 12, 2007 | 07:23 PM
nightcrawler7188's Avatar
what do you mean sidestep instead of feather? could someone explain this technique in more detail?
Old May 12, 2007 | 07:36 PM
jfw432's Avatar
Sidestep is exactly that basically allowing the clutch to fly up and engage as fast as possible and not letting the clutch up with your foot.
In most cars you sidestep to the left because it's more convenient but ours you have to side step to the right under the brake pedal which makes things complicated because of the dead pedal.
Old May 13, 2007 | 02:16 AM
prelewd/s2k's Avatar
so yes to sidestep no to feather?!?
Old May 13, 2007 | 03:01 AM
Nyther's Avatar
I think this should be the way:
1: 6K rpm
2: sidestep clutch, wheels instantly are spinning
3: hold rev above 6k rpm, wait until the tires stop spinning and get grip 4: on that exact moment floor it 100% and go go go
Old May 13, 2007 | 07:49 AM
and you guys are saying that if done correctly, this method won't harm anything on a bone stock s2000?
Old May 13, 2007 | 08:00 AM
S1999+1's Avatar
Won't harm? I wouldn't go that far. Doing this on any car is hard on it. This car wasn't intended for this to be done all the time and it will definately take its toll on it over time. For instance, we all know the S2000 has a 0-60 time in the low 5's right? Just because that is the 0-60 time doesn't mean that everytime you drive the car you should try to get it to 60 in the least amount of time. If all cars were drivin at their limit everytime they were driven, no cars would even last 50k miles. So getting to the point....will my car last longer or have less harm inflicted on it than yours since I've done no 6k RPM launches? Very likely. 6K clutch drops may not immediataly inflict damage on your car, but just 1 clutch drop is harder on the car than 20 normal take offs. In the long run, this shortens the life of the tranny, diff, clutch, and the engine.
