Launch Question?!
Old Jun 7, 2002 | 03:57 PM
Utah S2K's Avatar
[QUOTE]Originally posted by stockae92
[B]
really .. ??
Old Jun 7, 2002 | 04:34 PM
Gernby's Avatar
Former Sponsor
One thing that I should mention is that all of the streets I drive on are concrete, which is probably much grippier than asphalt.
Old Jun 8, 2002 | 06:06 AM
silvs2knvb's Avatar
I personally launch at 7K and find that is the best to do on the street and have done so in both my s2k's without any problem. I went to the drag strip lastnight and tried that and spun the whole time so i downgraded the launch to 6k and hooked up a lot better, so a lot of it depends on road conditions but i personally dont think you need to be worried about the differential unless you are running some kind of boost. Just my 2 cents
Jeremiah
Old Jun 8, 2002 | 08:26 AM
chrts's Avatar
my tires will not chirp, but i can get them to spin and the ass end feels like it kicks out a little bit about 50% of the time.
chris
Old Jun 8, 2002 | 01:43 PM
stockae92's Avatar
Originally posted by Utah S2K
Check your tire pressure....the S02's will chirp under power at 34 PSI. Use a good tire gauge not the one in front of the gas station.
Utah
i just did
i am running 32psi at all corners. and the manual suggested that we uses 32 psi at all corners.
should i run 34 psi instead? safe? front and rear different??
Old Jun 8, 2002 | 03:27 PM
yellow2001's Avatar
[QUOTE]Originally posted by gernby
[B]You are lucky that your clutch hooks up.
Old Jun 8, 2002 | 06:23 PM
Blk01S2k's Avatar
I chirp the tires whenever shifting fast into 2nd gear and ocassionally into third gear... i dont see why so many people have trouble chirping the tires.. i occassionaly chirp them at about 5-6k rpm.... its the speed at which you shift...
Old Jun 9, 2002 | 12:11 PM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by yellow2001
[B]
I think the clutch has to break in.
Old Jun 9, 2002 | 12:47 PM
iLikeBeer's Avatar
[B]
Old Jun 9, 2002 | 01:15 PM
Wisconsin S2k's Avatar
[B]
I've got 7700 miles on it now.
