LEDs in pre-MY04
Originally Posted by Dark,Sep 20 2006, 05:31 PM
New bulbs are in.
Pics will be up soon but for right now I have a video of the turn signal (all around). the front passenger side is still the stock bulb.
Video
excuse the dirt, its been raining non stop (except for the 2 days I work late
Video
Originally Posted by Dark,Sep 20 2006, 08:31 PM
New bulbs are in.
Video
Video
)So how do you like them, and are they as bright as stock?
Also, echoing GranPrix's query...did you need the relay or was it plug and play?
Craig
I had to replace the relay to get rid of the quick flash; I bought one from autolumination.com designed for leds...unfortunately 2 of the prongs were reversed so I was forced to run wires (with the correct ends) from the relay to the panel under the dash. It was simple but not the 'best' solution. It works great though.
Taillight pics (no brake, both lights are leds in the picture, garage was lit):
Originally Posted by JAXrsx,Sep 20 2006, 07:27 PM
Nice video clip. Kudos on leaving the passenger blinker stock for the comparison. You can really see the difference bewteen the two.
Craig
Craig
I like them alot, even though it was very costly for lights($100+)
Things I dont like was having to modify the rear turn signal wires to work with the leds.
If I did it again or end up changing anything I would go with a wider sidemarker led rather then the focused. Maybe an oval wide angle.
I will try and get some daytime shots for you guys.
http://autolumination.com/equalizers.htm
I bought the EP35/EP36. I still dont know which one exactly is the correct one to buy but IIRC its the EP34 (the bottom of the stock flasher has letters for each prong, I will check mine sometime tomorrow do see which prongs are which letter).
The LEDS you got should do the job just fine. How many led are the 7443? I think mine are 15, I am sure they are the same or at least close to it.
The 194 matrix leds should also look good in the sidemarkers!
I dont think its a dual filament...
Here is a good place to get the list of required bulbs:
http://www.sylvania.com/ConsumerProducts/A...ide/default.htm
