A Little Shook (Acciendet)
Old Aug 13, 2012 | 04:05 PM
S2k Ok's Avatar
So much bad grammar and spelling in here...may be why you people are crashing ;p jk
sorry to hear and gl in the future.
Old Aug 13, 2012 | 05:14 PM
nofearofdanger's Avatar
Condition / Spec of the tires please...?
Old Aug 13, 2012 | 05:46 PM
ahrmike's Avatar
Ok. Been there, done that (not the 24hr thing, the crashing thing).
You need:
SRS unit - small ECU like unit under the radio. pull the radio door, pull the radio, and you should be able to access it
Drivers side airbag plus, the cover - IIRC, you have to drop the steering column, separate the housing and you should be able to remove it. While its out, do NOT turn the steering wheel - theres a SRS Reel that needs to be kept in the same position or you WILL damage it.
Passenger side airbag, plus cover - pull the kick panels, be careful -in all likelihood it'll break - but its fairly cheap so no worries. You need to remove the cover before you can access the bags.
Driver seatbelt retractor
passengers seatbelt retractor - these are a PITA. You need to pull the seats, get the covers from the trunk out, and if you're lucky you'll be able to get it out.
You also need to google "reset ECU on Honda" and you should get a hit on what pins to cross... I don't remember it off the top of my head and don't want to give you bad info...its a PITA to do though, took me 3 tries. Be careful, since you can break your ECU if you cross the wrong pins.
--edit--
if you try to buy these items from the dealer, you need to provide your VIN or they won't give it to you. It'll probably end up costing ~5K+ last time I tried pricing the shit out.
If you buy these from people turning their S's to race spec, it'll still cost you ~800 if you're lucky. I got mine for ~$700 and change.
Old Aug 13, 2012 | 06:54 PM
rob-2's Avatar
I'm going to be rude... forgive me.
If within 24 hours you have an accident. I am going to suggest you're not qualified to repaire key safety equipment in the car. For your sake, a passenger or God forbid the next owner - get it done right and don't do it yourself.
Best of luck. Autox/track days will be a life saver for you. Seriously.
Old Aug 13, 2012 | 07:00 PM
gnows2k's Avatar
You need:
--edit--
Wow, this sounds like a big pita, I contacted the honda dealership and he said it might not be necessary. To replace the SRS unit, but still it hasn't been looked at yet though so it's a 50/50 chance.
Duly noted, I don't plan on doing it myself, I already thought it over and asked for some help replacing the stuff by a certified mechanic.
Old Aug 13, 2012 | 07:03 PM
gnows2k's Avatar
RE05A, tread is pretty low
Old Aug 13, 2012 | 07:23 PM
gnows2k's Avatar
does the 2002 have that many airbags? AFAIK the only airbags that went off is the steering wheel and passenger
Old Aug 13, 2012 | 07:39 PM
dantediss's Avatar
You my friend are looking at a pretty nice chunk of change for a repair, and not sure but some cars once the bags blow the car trips a fuel shutoff so the car wont start until its reset. Let me know what parts you need, my friend gets me parts at cost so if feasible i can price the list out and give you the total to call and order. Its actually good this happened though. Im not going to play dad or be a troll, but if you are now stuck paying a few k in repairs you are going to be more careful and mindful in the future. Just pm the parts you need and ill contact my friend and try and help out
Old Aug 13, 2012 | 07:54 PM
darcyw's Avatar
buy the best god damned tires you can...not all season crappy walmart specials...buy real tires- say star specs.
I know that's not what you asked, but for F's sake, don't be a tool.
good luck.
darcy
Old Aug 13, 2012 | 08:02 PM
gnows2k's Avatar
Well the car still starts surprisingly, and twice, enough to move my car out of obstruction, and into my friends apartment complex
