long term storage
Old Jun 17, 2008 | 11:55 PM
goobergum's Avatar
Default long term storage
i'm going to be out of the country for some time and I need to store my S2K for the entire time. It'll be indoors, but do you guys have any tips on what I should do? It'll probably be at least 3 months. Here are some things I've heard
Jack the car on stands
Take the battery out and hook it up to a continuous charger
Spray the inside of the cylinders to prevent rust (i'm in AZ so i don't think this is a concern)
Plug the exhaust so nothing gets in
Old Jun 18, 2008 | 05:10 AM
heathas2k's Avatar
Don't know how your rodent problem is out there... but I've heard numerous stories out here in pa of people storing cars and having rats or mice getting into parts of the car, making nests, chewing through wires, etc. Moth balls will keep them out, they hate the smell!
Old Jun 18, 2008 | 05:28 AM
ian05s2k's Avatar
1) Fill Gas tank to full
2) Place moth ball and dessicant pad on a plate and set one on the floor on each side of the car.
3) Change Oil and all other fluids you feel like changing. The more the better in my opinion
4) Wash, Dry and Wax car very good. Be sure to blwo the air out of the cracks.
5) Park car on thick foam to prevent flat sport in tires
6) Place Decon under and around the car.
7) Plug Exhaust & Intake with cloth
8) Inflate tires 5-10 psi higher than you would normally have them, but do not exceed the max psi for the tire.
9) If you have a car cover, wash it and then place it on the car
10) Say good night and try not to cry too much.
Hope that helps.
-Ian
Old Jun 18, 2008 | 01:44 PM
raisantos's Avatar
Hope that helps.
-Ian
fill gas tank to full?
i feel i always hear to empty the tank as much as possible???
Old Jun 18, 2008 | 02:20 PM
roflitzjinno's Avatar
you fill the tank to the highest because you dont want any debris to come in contact with the fuel pump i believe. and do you want to come back to your car with an empty tank?!
Old Jun 18, 2008 | 02:24 PM
IlleztImportz's Avatar
^ its not that, i too heard for it to be less gas, its cause the fuel will get old
pmk229
Dec 3, 2014 03:43 PM
chuhsi
Feb 5, 2010 11:30 AM
Vik2000
Dec 4, 2009 09:08 AM
S2KPC
Oct 28, 2009 08:02 PM
WRS2K
Jan 1, 2003 02:34 PM
