low on oil!
Old Jan 13, 2008 | 07:09 PM
13darkknight's Avatar
Default low on oil!
i have a MY07. i checked my oil this morning and noticed it was at or below the 'low' on the dipstick. isn't the car suppose to give you a light on the dash or something?
Old Jan 13, 2008 | 07:23 PM
Tx_Phantom's Avatar
Banned
The AP1s don't... The oil light means there is no pressure - its not a level amount light.
Old Jan 13, 2008 | 07:27 PM
R3DS2K's Avatar
oil light is not for how much oil you have but for oil pressure.. if the sensor shows low oil pressure.. the oil light will come on.. on most 4 cylinder engines.. the oil light will come on when you have less than 2 quarts.. and they are called idiot lights for a reason
Old Jan 14, 2008 | 07:29 AM
Sr2oD3's Avatar
try to make it a weekly routine of checking your oil and having a little bit for reserve in these cases so that you can add some.
the factory oil capacity is 5.1 quarts, keep it around there.
edit:
oops, forgot you're the big block, nvm that oil capacity...
Old Jan 14, 2008 | 08:37 AM
Woodson's Avatar
Have you owned a car before?
Old Jan 14, 2008 | 08:48 AM
RedY2KS2k's Avatar
Or ever read an Owner's Manual?
Old Jan 14, 2008 | 09:44 AM
CKit's Avatar
The light is a CEL telling you your engine blew because you ran low on oil.
Old Jan 14, 2008 | 09:46 AM
Doug1627's Avatar
Are you serious?
Old Jan 14, 2008 | 02:03 PM
The Twanksta's Avatar
umm, you ever changed your oil? your 07 should not be using ANY oil at all! I go 5k w/o coming off the top mark on the stick...
Old Jan 14, 2008 | 03:06 PM
NoRawkus305's Avatar
As everyone already explained, the light is not to show you your oil level but pressure. Now, due to our high-revving engines, our cars use up alot more oil than others. I feel you need to know this so your oil never goes down below "low" again. I recommend, you should check your level maybe everytime you fill up and just topping it off if needed. I would hate for any S to go bad because of negligence. They need our loving.
