Lowering Spring Question
Originally Posted by jackalope,Jun 29 2005, 09:42 AM
I have heard from a guy who does this professionally that the best way to do it is to loosen all of the suspension components, then let the car rest on its weight THEN tighten everythign down. this he said will keep anything from sagging, reducing the need for alignment.
Originally Posted by SoDakS2K,Jun 29 2005, 05:13 AM
If you want to have more aggressive handling, you can have a bit of negative camber. Anywhere between -1.5 to -2.0 will be fun! With the springs installed, you may not be able to get much less than -1.5 anyway. Just remember to rotate your tires every 5000 miles (if you're running SO2's) to keep the wear even.
And definitely do the work yourself and employ a friend to help. I finished the job myself in about 5 hours.
Originally Posted by JDM S,Jun 30 2005, 05:01 AM
sure you can. after i lowered my car with rsr springs, my rear camber was -3.5.
Originally Posted by dannnnny,Jun 30 2005, 07:17 AM
the heck is a camber?
gios2k
Mar 29, 2012 04:38 AM
Duy118
Jul 15, 2007 09:53 AM
