ls1/ls2 s2000
I've seen the 2jz thought about the rb26dett now im leaning heavily towards a ls1 or ls2 swap s2000. can anyone think of any potential problems there might be in doing this swap? as far as fitment reliability drivetrain issues...etc.
go for it.
heres some specs:
Engine Type
V8
Displacement
6.0L
364 CID
RPO
LS2
VIN
U
Bore
101.618-101.636 mm
4.0007-4.0017 in
Stroke
92.0 mm
3.622 in
Compression Ratio
10.9:1
Firing Order
1-8-7-2-6-5-4-3
Spark Plug Gap
1.02 mm
0.04 in
Block
Camshaft Bearing Bore 1 and 5 Diameter
59.58-59.63 mm
2.345-2.347 in
Camshaft Bearing Bore 2 and 4 Diameter
59.08-59.13 mm
2.325-2.327 in
Camshaft Bearing Bore 3 Diameter
58.58-58.63 mm
2.306-2.308 in
Crankshaft Main Bearing Bore Diameter
69.871-69.889 mm
2.75-2.751 in
Crankshaft Main Bearing Bore Out-of-Round
0.006 mm
0.0002 in
Cylinder Bore Diameter
101.618-101.636 mm
4.0007-4.0017 in
Cylinder Bore Taper - Thrust Side
0.018 mm
0.0007 in
Cylinder Head Deck Height - Measuring from the Centerline of Crankshaft to the Deck Face
234.57-234.82 mm
9.235-9.245 in
Cylinder Head Deck Surface Flatness - Measured Within a 152.4 mm (6.0 in) Area
0.11 mm
0.004 in
Cylinder Head Deck Surface Flatness - Measuring the Overall Length of the Block Deck
0.22 mm
0.008 in
Valve Lifter Bore Diameter
21.417-21.443 mm
0.843-0.844 in
Camshaft
Camshaft End Play
0.025-0.305 mm
0.001-0.012 in
Camshaft Journal Diameter
54.99-55.04 mm
2.164-2.166 in
Camshaft Journal Out-of-Round
0.025 mm
0.001 in
Camshaft Lobe Lift - Intake
7.78 mm
0.306 in
Camshaft Lobe Lift - Exhaust
7.77 mm
0.305 in
Camshaft Runout - Measured at the Intermediate Journals
0.05 mm
0.002 in
Connecting Rod
Connecting Rod Bearing Clearance - Production
0.023-0.065 mm
0.0009-0.0025 in
Connecting Rod Bearing Clearance - Service
0.023-0.076 mm
0.0009-0.003 in
Connecting Rod Bore Diameter - Bearing End
56.505-56.525 mm
2.224-2.225 in
Connecting Rod Bore Out-of-Round - Bearing End - Production
0.004-0.008 mm
0.00015-0.0003 in
Connecting Rod Bore Out-of-Round - Bearing End - Service
0.004-0.008 mm
0.00015-0.0003 in
Connecting Rod Side Clearance
0.11-0.51 mm
0.00433-0.02 in
Crankshaft
Connecting Rod Journal Diameter - Production
53.318-53.338 mm
2.0991-2.0999 in
Connecting Rod Journal Diameter - Service
53.308 mm
2.0987 in
Connecting Rod Journal Out-of-Round - Production
0.005 mm
0.0002 in
Connecting Rod Journal Out-of-Round - Service
0.01 mm
0.0004 in
Connecting Rod Journal Taper - Maximum for 1/2 of Journal Length - Production
0.005 mm
0.0002 in
Connecting Rod Journal Taper - Maximum for 1/2 of Journal Length - Service
0.02 mm
0.00078 in
Crankshaft End Play
0.04-0.2 mm
0.0015-0.0078 in
Crankshaft Main Bearing Clearance - Production
0.02-0.052 mm
0.0008-0.0021 in
Crankshaft Main Bearing Clearance - Service
0.02-0.065 mm
0.0008-0.0025 in
Crankshaft Main Journal Diameter - Production
64.992-65.008 mm
2.558-2.559 in
Crankshaft Main Journal Diameter - Service
64.992 mm
2.558 in
Crankshaft Main Journal Out-of-Round - Production
0.003 mm
0.000118 in
Crankshaft Main Journal Out-of-Round - Service
0.008 mm
0.0003 in
Crankshaft Main Journal Taper - Production
0.01 mm
0.0004 in
Crankshaft Main Journal Taper - Service
0.02 mm
0.00078 in
Crankshaft Rear Flange Runout
0.05 mm
0.002 in
Crankshaft Reluctor Ring Runout - Measured 1.0 mm (0.04 in) Below Tooth Diameter
0.7 mm
0.028 in
Crankshaft Thrust Surface - Production
26.14-26.22 mm
1.029-1.0315 in
Crankshaft Thrust Surface - Service
26.22 mm
1.0315 in
Crankshaft Thrust Surface Runout
0.025 mm
0.001 in
Cylinder Head
Cylinder Head Height/Thickness - Measured from the Cylinder Head Deck to the Valve Rocker Arm Cover Seal Surface
120.2 mm
4.732 in
Surface Flatness - Block Deck - Measured Within a 152.4 mm (6.0 in) Area
0.08 mm
0.003 in
Surface Flatness - Block Deck - Measuring the Overall Length of the Cylinder Head
0.1 mm
0.004 in
Surface Flatness - Exhaust Manifold Deck
0.13 mm
0.005 in
Surface Flatness - Intake Manifold Deck
0.08 mm
0.0031 in
Valve Guide Installed Height - Measured from the Spring Seat Surface to the Top of the Guide
17.32 mm
0.682 in
Intake Manifold
Surface Flatness - Measured at Gasket Sealing Surfaces and Measured Within a 200 mm (7.87 in) Area that Includes Two Runner Port Openings
0.3 mm
0.118 in
Lubrication System
Oil Capacity - with Filter
5.2 liters
5.5 quarts
Oil Capacity - without Filter
4.7 liters
5.0 quarts
Oil Pressure - Minimum - Hot
41 kPa at 1,000 engine RPM
124 kPa at 2,000 engine RPM
165 kPa at 4,000 engine RPM
6 psig at 1,000 engine RPM
18 psig at 2,000 engine RPM
24 psig at 4,000 engine RPM
Oil Pan
Front Cover Alignment - at Oil Pan Surface
0.0-0.5 mm
0.0-0.02 in
Rear Cover Alignment - at Oil Pan Surface
0.0-0.5 mm
0.0-0.02 in
Oil Pan Alignment - to Rear of Engine Block at Transmission Bell Housing Mounting Surface
0.0-0.25 mm
0.0-0.01 in
Piston Rings
Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Production
0.20-0.41 mm
0.008-0.016 in
Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Service
0.20-0.41 mm
0.008-0.016 in
Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Production
0.37-0.69 mm
0.015-0.027 in
Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Service
0.37-0.69 mm
0.015-0.027 in
Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Production
0.22-0.79 mm
0.009-0.031 in
Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Service
0.22-0.79 mm
0.009-0.031 in
Piston Ring to Groove Clearance - First Compression Ring - Production
0.030-0.10 mm
0.0012-0.0040 in
Piston Ring to Groove Clearance - First Compression Ring - Service
0.030-0.10 mm
0.0012-0.0040 in
Piston Ring to Groove Clearance - Second Compression Ring - Production
0.035-0.078 mm
0.0014-0.0031 in
Piston Ring to Groove Clearance - Second Compression Ring - Service
0.035-0.0078 mm
0.0014-0.0031 in
Piston Ring to Groove Clearance - Oil Control Ring - Production
0.013-0.201 mm
0.0005-0.0079 in
Piston Ring to Groove Clearance - Oil Control Ring - Service
0.013-0.201 mm
0.0005-0.0079 in
Pistons and Pins
Pin - Piston Pin Clearance to Piston Pin Bore - Production
0.002-0.01 mm
0.00008-0.0004 in
Pin - Piston Pin Clearance to Piston Pin Bore - Service
0.002-0.015 mm
0.00008-0.0006 in
Pin - Piston Pin Diameter
23.952-23.955 mm
0.943-0.943 in
Pin - Piston Pin Fit in Connecting Rod Bore - Production
0.007-0.02 mm
0.00027-0.00078 in
Pin - Piston Pin Fit in Connecting Rod Bore - Service
0.007-0.022 mm
0.00027-0.00086 in
Piston - Piston Diameter - Measured Over Skirt Coating
0.00-0.00 mm
0.00-0.00 in
Piston - Piston to Bore Clearance - Production
0.00-0.00 mm
0.00-0.00 in
Piston - Piston to Bore Clearance - Service Limit with Skirt Coating Worn Off
0.00-0.00 mm
0.00-0.00 in
Valve System
Valves - Valve Face Angle
45 degrees
Valves - Valve Face Width
1.25 mm
0.05 in
Valves - Valve Lash
Net Lash - No Adjustment
Valves - Valve Lift - Intake
13.27 mm
0.522 in
Valves - Valve Lift - Exhaust
13.25 mm
0.521 in
Valves - Valve Seat Angle
46 degrees
Valves - Valve Seat Runout
0.05 mm
0.002 in
Valves - Valve Seat Width - Exhaust
1.78 mm
0.07 in
Valves - Seat Width - Intake
1.02 mm
0.04 in
Valves - Valve Stem Diameter - Production
7.955-7.976 mm
0.313-0.314 in
Valves - Valve Stem Diameter - Service
7.95 mm
0.313 in
Valves - Valve Stem-to-Guide Clearance - Production - Intake
0.025-0.066 mm
0.001-0.0026 in
Valves - Valve Stem-to-Guide Clearance - Service - Intake
0.093 mm
0.0037 in
Valves - Valve Stem-to-Guide Clearance - Production - Exhaust
0.025-0.066 mm
0.001-0.0026 in
Valves - Valve Stem-to-Guide Clearance - Service - Exhaust
0.093 mm
0.0037 in
Rocker Arms - Valve Rocker Arm Ratio
1.70:1
Valve Springs - Valve Spring Free Length
52.9 mm
2.08 in
Valve Springs - Valve Spring Installed Height
45.75 mm
1.8 in
Valve Springs - Valve Spring Load - Closed
340 N at 45.75 mm
76 lb at 1.8 in
Valve Springs - Valve Spring Load - Open
980 N at 33.55 mm
220 lb at 1.32 in
heres some specs:
Engine Type
V8
Displacement
6.0L
364 CID
RPO
LS2
VIN
U
Bore
101.618-101.636 mm
4.0007-4.0017 in
Stroke
92.0 mm
3.622 in
Compression Ratio
10.9:1
Firing Order
1-8-7-2-6-5-4-3
Spark Plug Gap
1.02 mm
0.04 in
Block
59.58-59.63 mm
2.345-2.347 in
59.08-59.13 mm
2.325-2.327 in
58.58-58.63 mm
2.306-2.308 in
69.871-69.889 mm
2.75-2.751 in
0.006 mm
0.0002 in
101.618-101.636 mm
4.0007-4.0017 in
0.018 mm
0.0007 in
234.57-234.82 mm
9.235-9.245 in
0.11 mm
0.004 in
0.22 mm
0.008 in
21.417-21.443 mm
0.843-0.844 in
Camshaft
Camshaft End Play
0.025-0.305 mm
0.001-0.012 in
54.99-55.04 mm
2.164-2.166 in
0.025 mm
0.001 in
7.78 mm
0.306 in
7.77 mm
0.305 in
0.05 mm
0.002 in
Connecting Rod
0.023-0.065 mm
0.0009-0.0025 in
0.023-0.076 mm
0.0009-0.003 in
56.505-56.525 mm
2.224-2.225 in
0.004-0.008 mm
0.00015-0.0003 in
0.004-0.008 mm
0.00015-0.0003 in
0.11-0.51 mm
0.00433-0.02 in
Crankshaft
53.318-53.338 mm
2.0991-2.0999 in
53.308 mm
2.0987 in
0.005 mm
0.0002 in
0.01 mm
0.0004 in
0.005 mm
0.0002 in
0.02 mm
0.00078 in
Crankshaft End Play
0.04-0.2 mm
0.0015-0.0078 in
0.02-0.052 mm
0.0008-0.0021 in
0.02-0.065 mm
0.0008-0.0025 in
64.992-65.008 mm
2.558-2.559 in
64.992 mm
2.558 in
0.003 mm
0.000118 in
0.008 mm
0.0003 in
0.01 mm
0.0004 in
0.02 mm
0.00078 in
0.05 mm
0.002 in
0.7 mm
0.028 in
26.14-26.22 mm
1.029-1.0315 in
26.22 mm
1.0315 in
0.025 mm
0.001 in
Cylinder Head
120.2 mm
4.732 in
0.08 mm
0.003 in
0.1 mm
0.004 in
0.13 mm
0.005 in
0.08 mm
0.0031 in
17.32 mm
0.682 in
Intake Manifold
0.3 mm
0.118 in
Lubrication System
5.2 liters
5.5 quarts
4.7 liters
5.0 quarts
Oil Pan
0.0-0.5 mm
0.0-0.02 in
0.0-0.5 mm
0.0-0.02 in
0.0-0.25 mm
0.0-0.01 in
Piston Rings
0.20-0.41 mm
0.008-0.016 in
0.20-0.41 mm
0.008-0.016 in
0.37-0.69 mm
0.015-0.027 in
0.37-0.69 mm
0.015-0.027 in
0.22-0.79 mm
0.009-0.031 in
0.22-0.79 mm
0.009-0.031 in
0.030-0.10 mm
0.0012-0.0040 in
0.030-0.10 mm
0.0012-0.0040 in
0.035-0.078 mm
0.0014-0.0031 in
0.035-0.0078 mm
0.0014-0.0031 in
0.013-0.201 mm
0.0005-0.0079 in
0.013-0.201 mm
0.0005-0.0079 in
Pistons and Pins
0.002-0.01 mm
0.00008-0.0004 in
0.002-0.015 mm
0.00008-0.0006 in
23.952-23.955 mm
0.943-0.943 in
0.007-0.02 mm
0.00027-0.00078 in
0.007-0.022 mm
0.00027-0.00086 in
0.00-0.00 mm
0.00-0.00 in
0.00-0.00 mm
0.00-0.00 in
0.00-0.00 mm
0.00-0.00 in
Valve System
45 degrees
1.25 mm
0.05 in
Valves - Valve Lash
13.27 mm
0.522 in
13.25 mm
0.521 in
46 degrees
0.05 mm
0.002 in
1.78 mm
0.07 in
1.02 mm
0.04 in
7.955-7.976 mm
0.313-0.314 in
7.95 mm
0.313 in
0.025-0.066 mm
0.001-0.0026 in
0.093 mm
0.0037 in
0.025-0.066 mm
0.001-0.0026 in
0.093 mm
0.0037 in
1.70:1
52.9 mm
2.08 in
45.75 mm
1.8 in
340 N at 45.75 mm
76 lb at 1.8 in
980 N at 33.55 mm
220 lb at 1.32 in
for me, a LS1 would look good in certain cars... Right now I have only liked a LS1 in a FD... I don't know why, just do for some reason. It took me a few years to get around it that a LS1 is a awesome engine.
oh there is a LS1 evo if you haven't seen it yet
http://youtube.com/watch?v=iWW0-gQMWCc
ive seen LS1/2's in:
FD's
FC's
S13/14/15
R34
944's
928's
911's
as much as i HATE swaps in the s2k, the LS swap is about the only one i can stomach, the LS1/2 is one of the best motors in the last 10yrs.
FD's
FC's
S13/14/15
R34
944's
928's
911's
