Lubrication
Old Jun 28, 2019 | 12:49 PM
Winggs's Avatar
Default Lubrication
I am new to the S2000. Today I changed the differential fluid with Amsoil 75W 110 and the transmission fluid with Royal Purple Synchromax. Removed the shifter cleaned and lubricated it with Honda hight temp grease. I noticed that the shifting is a little smoother.
While under the car I looked high and low for some greasing points and found none. Can someone let me know what needs to be lubricated.
Thank you
Old Jun 28, 2019 | 03:19 PM
Car Analogy's Avatar
There are no grease zerk fittings if thats what you were looking for. There is no need for grease gun.
Engine oil, trans, diff. Clutch fluid (do a gravity bleed to initially swap all fluid, then every oil change turkey baster out resevoir and refill). Brake fluid (do a full swap at least every two years, gravity bleed).
There is a thread for new owners. Very comprehensive. Lots of important little things to do and inspect. Search for that thread.
Old Jun 28, 2019 | 03:43 PM
Winggs's Avatar
Great thank you great info looking forward to learning more.
Old Jun 29, 2019 | 07:36 AM
cosmomiller's Avatar
Top Answer: 1
You can "lube" up the rubber fittings and seals with a quality silicone grease. A little goes a very long way. You will see the term "Shinitsu" as that is the Honda grease but it is simply a silicone dielectric grease that you can find at automotive parts stores. I prefer 3M automotive grease. Comes in handy for household stuff as well as brake fittings and a few other things. 400C melt temp.
Anyway, work it in by hand to rubber seals to keep them fresh and sealing properly. Too much and it will leave a residue on the glass or your person and attract dirt.
Old Jun 30, 2019 | 08:56 AM
rpg51's Avatar
Another area to look at is the hood latch mechanism. Also the door latches, door hinges and the trunk hinge. Mine was very dried out. Again, a little goes a long way. The other small thing that makes a difference is the clutch free play adjustment. Hard to explain it in print but there is a good video here:
s2kvince
Apr 10, 2009 09:56 AM
jdmjeff
Jan 11, 2009 07:38 AM
TwistedS2k
Feb 28, 2005 02:35 PM
YellowSSM
Feb 14, 2004 01:31 PM
50cent
Jan 1, 2004 06:40 PM
