Lug nut torque?
I has heard that I could warp and/or ruin a brake rotor if I did it by hand. I know I could get the wheel on safely without breaking the studs by hand, but there's no way I could get the torque right by hand.
I have always hear that over torquing can warp a rotor or snap lugs. I have never seen this happen, however I use a torque wrench unless I do not have one then I will hand tighten (likely overly tight) until I can get home and put the torque wrench on it.
You know, I've known a few who just have a feel for how tight is right. I would always use a torque wrench on an alloy wheel.
You might: overtighten and not be able to remove a lug nut with the cheezy little wrench if you have a flat on the road, or
you might: undertighten and have a wheel loosen. It will ruin your wheel and is of course dangerous.
and I would never trust the so-called torque extensions that some tire centers use on their impact wrenches. I can testify that these are totally inaccurate.
Originally Posted by Gatsbee13,May 21 2007, 09:55 AM
If you do torque it by hand, torque it to 80lbs (oem spec).
80lbs with a torch wrench, otherwise its just guesswork.
