Map Sensor
Old Aug 9, 2002 | 11:47 AM
winter's Avatar
Default Map Sensor
A week ago I suddenly had a problem with acceleration hesistion/stumbling right around 7k rpm in all gears (well at least gears 1-3). Searching through the trusty S2ki board I quickly found threads with similiar sounding problems all pointing to the map sensor. So I followed the recommended procedure of tapping the map sensor a few times with a screwdriver and disconnected/reconnected the cable to it.
Well this solved the problem completely...however my S2000 comes out of std warranty in a couple of months and now I'm wondering if I would have been better off taking it to the dealer while it was malfunctioning so I could have gotten a brand new part. Does its misbehavior once indicate that its starting to go bad and should I now expect frequent problems with it or have others who have had to resort to pounding their map sensor had the problem stay fixed?
Thanks...
Old Aug 9, 2002 | 12:04 PM
Wesmaster's Avatar
The map sensor costs $43.82 from H and A...not really an expensive part, should it go bad.
Old Aug 9, 2002 | 12:21 PM
cdelena's Avatar
[QUOTE]Originally posted by winter
[B]...I'm wondering if I would have been better off taking it to the dealer while it was malfunctioning so I could have gotten a brand new part.
Old Aug 9, 2002 | 12:27 PM
Silver Bullet's Avatar
Is it recommended to reset the ECU (by disconnecting the battery?) after changing or tapping on the MAP sensor?
My car has not exhibited any high-speed hesitation but it does seem to "stumble" when the engine returns to idle while its cold (even with 3 bars on the temp gauge).
Old Aug 9, 2002 | 01:44 PM
acx's Avatar
acx
My car used to do this but has stopped hesitating above 6k, the only thing I have had done was the dealer TSB on the spark plugs. I don't think the two issues are related.
Where is the MAP sensor located, incase it happens again?
Old Aug 9, 2002 | 01:56 PM
winter's Avatar
Originally posted by acx
Where is the MAP sensor located, incase it happens again? [/B]
A picture is worth a thousand words, check this thread: Link
Old Aug 9, 2002 | 02:02 PM
acx's Avatar
acx
Thanks! Last time I did a search on this topic I didn't find that very helpful picture. Glad you pointed it out.
joefish1298
Jul 20, 2012 05:57 PM
veehexx
Aug 8, 2009 03:32 AM
vteconly
Aug 18, 2006 02:18 PM
MrV
Dec 5, 2004 06:12 AM
F1s2000
Dec 12, 2003 01:57 PM
