Max Negative Camber
Old Sep 2, 2007 | 07:56 AM
Papa's Avatar
Default Max Negative Camber
Im thinking fo running max camber, whats bad, and whats good,is it going to be any problems ???
Im not tracking, only for the street, purpose to fit wheels.
Please Help
Old Sep 2, 2007 | 09:03 AM
Project22a's Avatar
On the street?
Bad: Lower contact patch, increased inside tire wear if your toe isn't set right.
Good: Your wheels will fit.
Old Sep 2, 2007 | 04:30 PM
PedalFaster's Avatar
S2000 Talk.
Old Sep 2, 2007 | 05:09 PM
Ludedude's Avatar
Administrator
Old Sep 2, 2007 | 05:48 PM
RacerXI's Avatar
There are a lot of questions still to be answered. Are you on stock suspension, lowered, etc.? Max camber could be -3 or if you're stock you won't get more than about -2.
Old Sep 2, 2007 | 11:49 PM
LostMotion's Avatar
There is no reason to max your camber front or back for the driving you are doing. If you aren't tracking or driving canyons you should run 1 deg max in the front, 1.75 degree max in the back and put your caster at 6.5 to 7. You could even consider a little less camber in the front, like .75 deg.
Old Sep 3, 2007 | 01:04 AM
Papa's Avatar
i have coilovers
balkolite
Jun 12, 2017 12:59 PM
mrbond413
May 18, 2014 09:57 AM
Sneeze2K
May 20, 2013 01:30 PM
mavericckk..
Jul 28, 2009 08:34 AM
c32b
Feb 27, 2008 07:56 PM
