Misaligned Bumper Panels
Old Sep 9, 2007 | 02:58 PM
BD89's Avatar
Default Misaligned Bumper Panels
Well, I'm in the market for an S2000, and was all set to put a deposit on a yellow one tomorrow, a 2006. However, I went and checked it out, and I found this:
What could have caused this? It looks like a serious mismatch, especially evident in the 2nd picture. Carfax says no accident, I was told the car was in no accident, but I'm so wary about buying one with a body panel mismatch like this.
Old Sep 9, 2007 | 03:02 PM
Startrek's Avatar
there is a clip back there. It might be able to be adjusted and re-clip (really hard to explain) I would remove bumper and push the clip down then try to push it back.
Also there is a screw in the fender liner right. I would remove it try to push the bumper back and try to correct it.
Sorry both hard things to explain PM if you need more help
Old Sep 9, 2007 | 03:03 PM
BD89's Avatar
I'm not worried about fixing it, I haven't bought the car, but I don't want to buy a car that's been in an accident. The car also has a very scraped front lip, and all tires have rash on them. All these things are not very indicative of a well cared for car.
Old Sep 9, 2007 | 03:04 PM
INTJ's Avatar
My new one looks just like that. No accident, worse when it sits in the 110 F sun.
Old Sep 9, 2007 | 03:05 PM
BD89's Avatar
The other side of the vehicle was perfectly fine, I don't see why one side should be different. And I've never heard of heat distorting body panels.
Old Sep 9, 2007 | 03:11 PM
umop-apisdn's Avatar
Unfortunately, it's a fairly common problem.
https://www.s2ki.com/forums/index.php?showtopic=311610
Old Sep 9, 2007 | 03:19 PM
BD89's Avatar
Very interesting...has Honda issued a recall for this? Just a short skimming of the threads make it evident that this is a very prevalent issue.
Old Sep 9, 2007 | 04:13 PM
BD89's Avatar
I just checked all the photos - none of the S2000s seem to be as mis-aligned as that one. Also, the car seems to have cosmetic damage - all four wheels have varying degrees of rash, and check out the front lip:
Do all S2000s have that much wear on the lip? This car that I'm looking at only has 5K miles.
Old Sep 9, 2007 | 04:19 PM
MasterVtec's Avatar
It only takes one or two misinterpreted curbs to scrape a front lip like that. For a used car I would say it's normal.
Old Sep 10, 2007 | 03:40 PM
INTJ's Avatar
Mine is symmetric. The panel is plastic. The clips come loose. Look at the car on a lift and check the seams for rewelding or buckling to assess if it has been in an accident.
