Misshifted from 3rd to 2nd
Well im 18, and i dont have the money right now. I really dont want to tell my dad because he would be royally pissed. Do you think it would be ok to wait o say two weeks until i had the money to have it checked? I do have a wrangler that I could drive if need be until then.
Originally Posted by Wisconsin S2k,Mar 5 2006, 11:24 AM
I'd drive the wrangler then until you have the cash. sure you could be "wasting" your money, but wouldn't you rather know for sure, rather than make a gamble that could cost you several thousand? I would.
I'm not too knowledgable about engines but from what I heard, if the valves are going to drop toward the pistons, you would hear valve to piston contact. So if you hear something funny from your engine, you know you need to get it fixed.
Why pull the head? You can check the retainers with a flashlight after pulling only the rocker cover. While the cover is off, check the valve clearances, then run a compression check if you think there may be a bent valve. Why pull the head?
If in doubt it only takes a few minutes to pull the rocker cover and inspect the retainers.
