Mooncraft Hardtop - how does it work?
Old 12-29-2006, 11:29 AM
^AnDre^'s Avatar
Default Mooncraft Hardtop - how does it work?
I am just wondering on the install process on the mugen HT, and at that its removal for when you feel like driving a convertable again.
EDIT: Meant to ask about Mooncraft Hardtop - not Mugen.
Old 12-29-2006, 11:33 AM
neveronlines2k's Avatar
Its awkward to hold so removal is a two person job. just un-due the catchers and the mounting brackets on the sides and lift off.
Old 12-29-2006, 11:35 AM
^AnDre^'s Avatar
so you are telling me it isnt fastened to the trunk?
what about if you want to open the trunk (i assume that the ht will split at the line above the window and allow to do so).
Old 12-29-2006, 11:50 AM
Stratocaster's Avatar
It mounts and installs just like the OEM HT does. The trunk works as it was designed
Old 12-29-2006, 11:59 AM
^AnDre^'s Avatar
My bad... i meant spoon monocraft roof.
Old 12-29-2006, 12:28 PM
OK, that one the trunk still works. You just have to open the back 1/2 first. We have one in the shop. It also is a bolt on installation not like Mugen or OEM.
Old 12-29-2006, 04:02 PM
^AnDre^'s Avatar
so then no more convertable then. hmm.. dam it looks so sweet though.
Old 12-29-2006, 06:20 PM
Poindexter's Avatar
Fixing title for you, and your first post.
Old 12-29-2006, 06:35 PM
It can be removed. It is just not as easy as the Mugen or OEM HT to remove. You have to unbolt a few bolts to get it off. It fully supports the softtop when installed.
Old 12-30-2006, 03:21 AM
^AnDre^'s Avatar
are the bolts into the exterior body? basically what I am getting at is will the mounting holes be visable when the top is off?
Quick Reply: Mooncraft Hardtop - how does it work?
