Mugen Header Dyno Sheets
Old Nov 28, 2000 | 02:06 PM
krazik's Avatar
Administrator
Here is a smaller version of the 2 runs paired
For Other Plots and Higher Res Versions, go to
http://albums.photopoint.com/j/AlbumIndex?...76810&a=9809833
Old Nov 28, 2000 | 02:07 PM
krazik's Avatar
Administrator
Oh yeah, took lots of pics.. I will post those l8r.
Old Nov 28, 2000 | 02:14 PM
Jay Li's Avatar
How come the numbers were down from when you had the runs with the HKS? Was the weather warmer?
Old Nov 28, 2000 | 02:17 PM
GTRPower's Avatar
kreazik-s2k-
Hey... was the car using the stock ECM? You'll see less variance between the dyno runs if you had it running with a more aggressive ECM (like Mugen). It looks like your car was getting heat soaked and the stock ECM retarded the timing abit.
-Nick
[This message has been edited by GTRPower (edited November 28, 2000).]
Old Nov 28, 2000 | 02:31 PM
Porsche518's Avatar
Hey krazik does the car have any other mods? Or just the headers.
Old Nov 28, 2000 | 02:37 PM
krazik's Avatar
Administrator
[QUOTE]Originally posted by GTRPower:
[B]Hey...
Old Nov 28, 2000 | 02:43 PM
krazik's Avatar
Administrator
See Sig.
Old Nov 28, 2000 | 02:46 PM
krazik's Avatar
Administrator
But look at the torque curve!
Especially check out the higher res version. http://albums.photopoint.com/j/ViewPhoto?u...9833&p=34250113
Click here then on the graph.
The car is noticably peppyier(sp), is also much easier to get moving from a stop, and the headers weigh significatly less
[This message has been edited by krazik-s2k (edited November 28, 2000).]
Old Nov 28, 2000 | 03:54 PM
song's Avatar
krazik:
Something funny is going on. It was also 55-65 degrees on the day you dyno'd this header. This is actaully a bit cooler than when the exhaust system runs were performed.
So were the initial runs showing better results than subsequent? Did you do 3 runs each again? Since you had to swap headers, I'd guess that there was a 30min-1hr cooldown between the stock and Mugen runs. That should be enough time to stabilize the heat soak.
I guess I'm wondering what your analysis of all this is. Also, does it sound any different?
Old Nov 28, 2000 | 04:11 PM
RandyP's Avatar
Looks like more low end torque, with no high end gain. It should be faster in the city but about the same on the track.
