Mugen Header Dyno Sheets
Can someone please tell me which curve says what? I mean, is the higher one with the mugen header or the stock?
What color belong to which runs with mugen header. for all we know, we could have lost power with the header
[QUOTE]Originally posted by nwk00:
[B]Can someone please tell me which curve says what? I mean, is the higher one with the mugen header or the stock?
Originally posted by song:
krazik:
Something funny is going on. It was also 55-65 degrees on the day you dyno'd this header. This is actaully a bit cooler than when the exhaust system runs were performed.
So were the initial runs showing better results than subsequent? Did you do 3 runs each again? Since you had to swap headers, I'd guess that there was a 30min-1hr cooldown between the stock and Mugen runs. That should be enough time to stabilize the heat soak.
I guess I'm wondering what your analysis of all this is. Also, does it sound any different?
krazik:
I am pretty sure heat soak is part of the issue.
The power curve with the header is exactly as advertised, more area under the curve with a nice increase in low end torque and a bump from 6000 to 7200. Hard to ask for much more when you are replacing a header that is excellent as is.
I
I
man, I just got back from about an hour of city driving. From a stop, this header is a MUST have.
Anyone that uses their car as a daily driver or EVER gets stuck in traffic, the additional 5-6ftlbs at the bottom, complete remove the bog that you get at low RPM starts, AND the car picks up and gets moving with much less finess than required before.
Guest
Posts: n/a
Maybe the Mugen headers transfer MORE heat to the engine compartment than the stock headers do.
So you lost 2 HP peak and shifted it lower down in the rev range and picked up 4 pounds of torque.
Doesn't seem worth the effort. I bet that just replacing the stock airfilter with a K&N would yield a more impressive dyno plot.
