My 04 Dyno (kinda low)
Originally posted by CrazyPhuD
So actually the MY04 wheels are heavier but not 'much' heavier....
MY00-03 wheel weights
F 17.5lbs R 18.6lbs
MY04 Wheel weights
F 17.6lbs R 20.5lbs
S-02 weights
F 22lbs R 25lbs
RE050 weights
F 22lbs R 27lbs
MY00-03 totals
F 39.5 R 43.6
MY04 totals
F 39.6 R 47.5
So MY04 MY00-03 fronts have effectively identical weights and the MY04 rear is ~10% heavier than MY00-03.
F 17.5lbs R 18.6lbs
MY04 Wheel weights
F 17.6lbs R 20.5lbs
S-02 weights
F 22lbs R 25lbs
RE050 weights
F 22lbs R 27lbs
MY00-03 totals
F 39.5 R 43.6
MY04 totals
F 39.6 R 47.5
Hmmm. I wonder if a 10% weight difference - which probably means a more-than-10% polar moment of inertia difference? - could account for the differrence in Dynapack and Dynojet results?
(Not to rule out human error, of course.)
Originally posted by 2_and
i might be wrong, but if you guys notice...they only pulled only up to 8rpm...should have gone 9 rpm.....
Dude, it's an '04. If he went to 9K he could have done it once. Ever.
So no reflash possible with the s2k ECU......actually I have a feeling that the 2.2L will be like the 2.0L, it'll make max power around 8300-8400. You'll gain some but not alot, plus you are taking away some of the safety margin of the engine. Since you may only gain 3hp...is it worth it?
