My car STILL drifts to the right
Old 11-13-2006, 06:33 PM
indianmagi's Avatar
Default My car STILL drifts to the right
Hello all,
I got the S2000 back from the body shop not long ago and been taking care of little problems here and there after it had been there for 6 months. I had a thread with my story. One of the problems was that it was drifting to the right, especially at higher speeds (freeway speeds). I've gotten alignment 3 times, and tire pressures are fine. STILL it drifts to the right and is annoying because any time i hit a dip, the car wobbles. So I'm stuck...what the hell could be the problem?
Old 11-14-2006, 09:40 AM
indianmagi's Avatar
Old 11-14-2006, 10:34 AM
AssassinJN's Avatar
What did you do to your car? Or link to your previous story?
If it was an accident (and a pretty bad one) then maybe your frame is bent. Did you replace all suspension parts in the area of impact? Control arms etc?
Old 11-14-2006, 06:49 PM
indianmagi's Avatar
https://www.s2ki.com/forums/index.php?showt...y+got+mine+back
It is actually my brother's car and he crashed it. You are right it has to be something other than simply alignment, and I'm pretty sure everything was replaced, but the I can never be sure with that bodyshop...i'm not sure what i should do next.
Old 11-14-2006, 07:38 PM
diabolus2k's Avatar
Do you have a nail or other object stuck in your tire? If the alignment is good and the tire pressures are good, then this definitely could be causing what you're experiencing...
Old 11-14-2006, 08:32 PM
cyman83's Avatar
if the alignment is good, most car do drift to the right. its for safety concerns, like if you were to fall asleep on the road. and most of the public roads are created for the same reason, it has a slight slant to the right side of the road
Old 11-15-2006, 05:28 AM
AssassinJN's Avatar
Cars should not drift right from factory and roads are slanted for run-off during heavy rain, not for safety. Also your car should definitely not "wobble" when you hit a dip.
Still need more information on the accident (speed, what part hit, what did he hit, etc.) Chances are if he was going at a pretty good clip, he probably bent the frame. Good luck.
Old 11-15-2006, 06:32 AM
millertown15's Avatar
Save money and DONT get another alignment. Go and put it on a frame machine. If its not too bad they can yank it back straight. good luck.
Old 11-15-2006, 09:02 AM
melonheadr6's Avatar
lol
Old 11-15-2006, 09:36 AM
shotiable's Avatar
my ap2 is stock and never been in an accident. got it brand new, but it pulls right at low speeds...
Quick Reply: My car STILL drifts to the right
