My first S2000 mechanical problem
Old Aug 1, 2005 | 10:53 AM
vader1's Avatar
Default My first S2000 mechanical problem
My first problem with the car (currently 20,000 miles) is that when putting down the top, the driver side window, instead of going all the way down, is going down about 1/3 of the way. Then when the top is down I have to use the window button to put it down the rest of the way. Anyone have this problem and know where to start?
Passenger side works fine.
Thanks in advance.
Old Aug 1, 2005 | 11:03 AM
Planets's Avatar
I have seen this problem on the board before, it is a known issue. You are going to have to search for this one, I know it has been gone over here before but I can't remember what exactly the fix for it is.
Old Aug 1, 2005 | 11:05 AM
steven975's Avatar
the problem is the window regulator gets dirty and malfunctions.
if you have a service history with the dealer, it will very likely be covered by goodwill if you show them the TSB.
Old Aug 1, 2005 | 11:06 AM
xviper's Avatar
Your window regulator is kaput. Honda has a TSB on this. Are you still under warranty? You can try the window "reset" trick but this may only be temporary. Use door button to lower window. Hold it till you hear a click. Raise the window and continue to hold the button till you hear a click. Shut off key and turn back on. See what happens.
ps. Common!
Old Aug 1, 2005 | 11:08 AM
vader1's Avatar
Many thanks gents! I will give it a try.
Anybody with the tsb number or link feel free to post it!
Old Aug 1, 2005 | 12:23 PM
r_duff's Avatar
https://www.s2ki.com/forums/index.php?showtopic=275210
enjoy!
nwaaa11
Nov 24, 2010 02:27 AM
jeaent
Aug 13, 2005 11:01 AM
Venomous S
Jul 8, 2003 09:48 AM
Squeezer
Mar 21, 2001 06:03 PM
