Automatic Driver's Window
Old Aug 11, 2005 | 06:26 PM
jeaent's Avatar
Default Automatic Driver's Window
Recently the driver's side window stopped automaticall going down when putting the top down and the had to keep button pushed for the window to go down all the way. The dealer said they had to reprogram the window. It is now working - does this make sense?
Old Aug 11, 2005 | 06:34 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Yes...there's a tSB on it.
There is also a way to "reprogram" it as they did, but it's not a cure-all. The problem may return.
Old Aug 11, 2005 | 07:16 PM
xviper's Avatar
I'd give it a week ----------- maybe.
Old Aug 11, 2005 | 07:20 PM
Slows2k's Avatar
A new window regulator is the actual repair. All 00-02's are under the TSB 01-008, and some 03's.
If you're still under warranty, get the regulator replaced.
Old Aug 11, 2005 | 07:22 PM
Veritas's Avatar
Glad someone asked this I've had the same problem recently. The window chooses when it wants to go up and down
Old Aug 11, 2005 | 08:45 PM
dhayner's Avatar
Honda will sometimes replace the regulator at no cost even after expiration of the warranty. They replaced mine a few weeks ago with four years and 24,000 miles on the car. I had to press the dealer to go to AHM for approval.
Old Aug 12, 2005 | 12:03 PM
steven975's Avatar
My dealer did my MY01 with 43K shortly after I got it. I showed them the TSB and they approved it. I "let" them have a 45K service so that greased the wheels a bit.
Old Aug 12, 2005 | 02:26 PM
Slows2k's Avatar
Having the dealer do some service work doesn't hurt your chances for goodwill consideration.
Old Aug 12, 2005 | 06:02 PM
r_duff's Avatar
ITS POSSESSED!!!!!!!!!
Old Aug 12, 2005 | 07:48 PM
Venomous S's Avatar
My driver's window would only go down 1/4 of its travel so I did the up/down quick fix and since then, almost 2 years later still hasn't acted up...
