My J's Racing S2000 Project!
Old Dec 23, 2005 | 05:09 AM
  #101
efthimios's Avatar
bump for the Greek προαγωγός
Old Dec 23, 2005 | 02:43 PM
  #102
efthimios's Avatar
mmmmmmm....I wanna see new pix!!!
Old Dec 26, 2005 | 12:18 PM
  #103
energetic's Avatar
I will get some photos once I get my new camera delivered.
Old Dec 30, 2005 | 11:26 PM
  #104
energetic's Avatar
Yesterday night I had my OEM TB removed and fitted temporary the Spoon TB that I found. The OEM TB will be flying all the way to J's Racing in Japan and will be expected to be returned under J's Racing specs on about 15/01/06. In the meantime I enjoy Spoon TB, BUT am facing the following problem. Although I reset the ECU it seems that my rpms on idle condition are 1400-1500rpms instead of 900-1000rpms and although I havent touched anything that can cause this, am wondering why this is happening.
Please note that I had to remove the Map Sencor & TP sensor (cant remember what this does) in order to be fitted on the Spoon TB. The previous owner of the Spoon TB advised me that I have to do some adjustment on the TP sensor position. I have noticed that the screw holes in the location of the TP sensor are egg shaped and I think that by moving the bolt-on location this can adjust the rpms that are higher at the moment. Please note that I didnt made any adjustment on the throttle cable and all clearances are correct.
What should I do? In the meantime I cant find any guidelines on the S2000 Technical manual. Your help will be appreciated.
Old Dec 31, 2005 | 12:43 AM
  #105
S2000_Europe's Avatar
marios that is weird, the only difference beetween a Spoon TB and OEM is the diameter, the TP sensor is de same.
have a look here:
https://www.s2ki.com/forums/index.php?showtopic=209708
Old Jan 2, 2006 | 12:11 AM
  #106
energetic's Avatar
Thanks for the link. Already checked that but I have the feeling that something has to do with the TP sensor.
By the way... Happy New Year!
Old Jan 3, 2006 | 07:58 AM
  #107
energetic's Avatar
Any more advice on this one?
Old Jan 3, 2006 | 09:04 AM
  #108
prez1967's Avatar
no advise on the throttle body issue but i thought i'd chime in and say hey to a fellow greek!
Your ride is looking good... I am always left dissapointed during the summers when i'm on vacation, i can never seem to find the greek car culture to be as strong as it is here in america.
I come to athens for a few weeks each summer (i say in Paleo Faliro) but my family is originally from Kasos. Keep up the good work with the project!
Old Jan 3, 2006 | 12:54 PM
  #109
mucter's Avatar
there is a allen bolt/nut combo that the throttle rests against, this sets the maximum that the butterfly valve can be closed. It is located towards the bottom of the TB next to the throttle cable.
This bolt may be adjusted too high, thus holding your butterfly valve open and rasing your RPMS. To know for sure you would have to check the voltages coming out of your TPS, I can't remember exactly what range it should be, you don't want to change the position of the bolt without checking the readings from your TPS.
Adjust the positioning of the TPS to put the voltages within spec at WOT, then check with the throttle closed, if it is not in spec with it closed, you may need to adjust this bolt.
If this Spoon TB has been used before, the previous owner may have adjusted that bolt to raise idle RPMS.
HTH
Old Jan 3, 2006 | 11:21 PM
  #110
energetic's Avatar
@mucter
Thanks for the info mate, you have just reconfirmed what I had in mind and will check this out. I will check this out as you said. Oh and by the way it is a Spoon TB not a MUgen.
Thanks again.
@prez1967
Greece is obsessed with cars and you can seen them during night time mostly.
Next time you come to Athens let me know.
