My J's Racing S2000 Project!
Old Apr 26, 2006 | 04:29 AM
  #251
Amuse Boy's Avatar
Most probably - I can't remember so clearly now. But the whole rev range is strengthened - feels like a completely different car. I sometimes don't even rev to the limiter as you land into the VTEC zone in the next gear.
I will be removing the ECU and straight pipe in a week or two - need to get the MOT test done!
Old Apr 26, 2006 | 06:17 AM
  #252
energetic's Avatar
Thats exactly how the S feels like!
They send me also the NGK no.8 plugs but I havent fit them yet so am running on the stock ones for now.
Old Apr 26, 2006 | 06:48 AM
  #253
Amuse Boy's Avatar
Definitely put the plugs in and make sure you check the gaps. The car pulls a lot harder on the bottom end and the idle is smoother.
Old Apr 26, 2006 | 06:53 AM
  #254
energetic's Avatar
What gap did you use? 0.9mm, 1.0mm or 1.1mm?
Old Apr 26, 2006 | 06:57 AM
  #255
S2000_Europe's Avatar
do not get me wrong but plugs would not do anything regarding power
Old Apr 26, 2006 | 07:19 AM
  #256
Amuse Boy's Avatar
Juan - you are right - power will not increase but the way it is delivered will. Very smooth and the torque is better at lower revs. I don't run a shield on the manifold like stock yet I have not felt the car bog from heat when driving for several hours.
Marios - I gapped mine at 1.0mm.
Old Apr 26, 2006 | 07:27 AM
  #257
xstremer's Avatar
i'm sure this has been discussed before, but is it ok to run 93 octance with j's ecu?
Old Apr 26, 2006 | 07:29 AM
  #258
Amuse Boy's Avatar
Yes it is. The J's ECU still utilises the knock sensor but it's not as paranoid as the stock setup.
Old Apr 26, 2006 | 07:31 AM
  #259
energetic's Avatar
J's Racing asked me how many octane fuel I will be running, and I reply to them 100 octane... So the mapped the ECU accordingly... I dont know if they do different mapping for lower octane than 100.
Old Apr 26, 2006 | 07:33 AM
  #260
energetic's Avatar
I just saw Amuse_Boy reply! Thanks mate.
