My new (used) s2000!
Old Oct 2, 2005 | 06:00 PM
460cidpower's Avatar
Cool My new (used) s2000!
I just got at auction a 2001 s2000 with 46k miles.
What maintanece should be done?
I know I need to change the engine oil/filter and gear box fluid, but I don't know the capacities or the type.
Also, it has a slight vibration in the front right tire. What typically would cause that?
Old Oct 2, 2005 | 06:01 PM
sdputerbum's Avatar
welcome!
here spend 5 hours reading this https://www.s2ki.com/forums/index.php?showtopic=108435
Old Oct 3, 2005 | 06:44 AM
xviper's Avatar
How do you know that it's the tire and which side it's coming from?
I would suggest you buy yourself an owner's manual or if you want to go all out, a service manual. You can get either from www.helminc.com.
Oh, and don't forget the diff fluid.
Old Oct 3, 2005 | 07:03 AM
texasjohn's Avatar
Dont buy a manual there is one to download
https://www.s2ki.com/forums/index.php?showtopic=322669
Old Oct 5, 2005 | 06:12 PM
I found the source of the vibration. The driver front tire rim is warped. I'm gunna buy a refurbished one from a body shop for $150.
I did pay the $70 for the service manual though, because I like to have the manual by me when I'm workin on the ride.
Also, I've noticed that my milage pretty much sucks. ~15MPG. What mostly kills milage? (I've been keeping my foot out of it too!)
Old Oct 5, 2005 | 06:19 PM
Also, what is a good subsitute for the DOT3 brake fluid? Will valvoline synpower work? It says it exceeds dot 3 and 4 specs.
Old Oct 5, 2005 | 06:24 PM
MaxGeek's Avatar
Valvoline SynPower works great. I use it myself. (for my brake and clutch)
Old Oct 5, 2005 | 07:18 PM
At what RPM does yours run at 75MPH? Mine is 4000RPM, (in 6th gear) which seems high, but i've never been in any other S2000's to know.
Old Oct 5, 2005 | 07:26 PM
xviper's Avatar
All kinds of things can make fuel economy bad - wrong tire pressures, leaking injectors or other type of fuel leak, dirty air filter, too high a viscosity of oil, bad gas, running in too low a gear at too high a speed, shifting at too high an rpm on a routine basis, a mod gone bad, dragging brakes, bad alignment.
I've been using this for years.
Your car is running exactly as it should (speed vs rpm). Don't worry, you've got 5000 more rpm to go.
Old Oct 6, 2005 | 01:06 PM
Is there a washable air conditon filter availible for it? Replacing the stock paper one will get old fast....
