Nasty Rattle in Front End When Engine Shuts Off
Old Jan 14, 2002 | 08:36 AM
The Raptor's Avatar
Active Streak: 30 Days
Default Nasty Rattle in Front End When Engine Shuts Off
Just started noticing it. I'm due for the final service before the warranty expires this week. What is it and what should I do?
Old Jan 14, 2002 | 09:10 AM
bayarea408's Avatar
[QUOTE]Originally posted by The Raptor
[B]Just started noticing it.
Old Jan 14, 2002 | 11:33 AM
The Raptor's Avatar
Anyone?????
Old Jan 14, 2002 | 01:09 PM
Takashi KazuMori's Avatar
No explanation to that ... Mine does that as well, it doesn't really bother me anymore.
Old Jan 14, 2002 | 01:22 PM
Spryguy's Avatar
Anyone?????
You might want to check the hood-prop rod.........The plastic holder may be loose/broken.
Old Jan 14, 2002 | 01:30 PM
George's Avatar
I don't get a rattle, but I get a little squeak as the last jigglies die down when I turn off the engine. Kinda like a girl sneeze.
Old Jan 14, 2002 | 01:37 PM
xviper's Avatar
Heat shield(s), dry engine mount rubbers. If you go out and watch your engine when someone turns it off, you see it "shudder" a bit. If there is something slightly loose, or bent out of shape or dry rubber bushings, this shudder produces enough physical engine movement to cause any of these things to make its own characteristic noise. You could go absolutely nuts trying to zero in on it and stop it.
Old Jan 14, 2002 | 01:42 PM
AusS2000's Avatar
Is it a jiggle or is the engine running on and detonating? This was common in pre-fuel injected cars. Contaminants in the cylinders ignite any residual gases after the engine has been turned off and it sounds like a fairly clunky rattle.
Old Jan 14, 2002 | 08:17 PM
Elistan's Avatar
Pure shot in the dark, but - maybe the valves need adjusting?
Triple-H
Mar 18, 2006 11:36 AM
ukliam
Nov 1, 2002 08:51 AM
WRS2K
Jul 14, 2001 10:11 AM
Speed 2000
Apr 16, 2001 10:07 AM
stookster
Apr 4, 2001 07:22 AM
