need clutch replacement at 3000 k ?
well this is my first post, but is it normal for the clutch to be replaced at such low miles? I did bring it to the dealership and they told me they would have to check out the clutch and see what the problem is. Then they would report it to the honda headquarters to see if it would be under warranty. If not then I would have to pay for the surgery. Does anyone know if there is any warranty on the clutch?
Thanks for the replies
As far as I know its covered under the factory warranty. I was told I can replace the clutch as many times as I want aslong as its under waranty(and ofcoarse really messed up) so im pretty sure they should fix it for free.
Given the car has only 3000 miles on it it would seem likely that the clutch is faulty and should be replaced under warranty.
).Seriosly, what Tifosi Red said is true. The dealer will evalute whether the car has been abused and if not the item should be warranteed. Good luck with the repair and I hope that you're back on the road soon.
MIC
Sep 29, 2004 08:19 AM
