Need driving tips for s2k!
Yes, knowing the point of engagement without using gas is THE most important part when learning to drive manual transmissions.
It's good to hear that you're able to get your S moving without reving past 1-2k RPMs, but don't be too worried because the MT's these days are extremely forgiving.
Originally Posted by Speedster,Mar 15 2006, 10:41 PM
Practise on a level surface somewhere quiet, with no throttle input. That's right, no throttle. At the point where the clutch is starting to grab (slack point), you'll have to pause/or hold it and allow to car to start moving slowly. Once it starts to get going, you can safely release the clutch all the way.
Soon, you will be able to release the clutch faster and faster even with no gas as you will get a "feel" for the slack point. Then in real situation, you'll be using just a little gas and being able to release it quickly and confidently.
Be smooth, gentle, patient and practise, practise, practise.
No gas.
Slowly let the clutch out.
If you stall, you let the clutch out too fast.
I have not tried this with the car yet, but the bike would get going to about 7mph without using any gas.
This skill came in really handy. I now instinctively use the clutch as a "tool". When I test drove the car earlier in the week, I spent about a minute getting a feel for where the clutch would grab, and how the clutch felt at different positions of release and engagement.
I just got my S2000. I am already able to feel the clutch out, and use it to keep the car from rolling back when I am starting on a hill.
My plan is to practice on a vacant parking garage ramp this weekend, just to make sure I have it all down.
Good luck!
- I spent all day stalling the bike out before I learned this trick, and picked it up pretty quickly after learning this trick.
Originally Posted by mloomis,Mar 16 2006, 09:32 PM
Riceboi, may I ask how the original test drive of your S2000 went? Did you buy the car from a private party or a dealership? Just wondering.
Originally Posted by nightcrawler7188,Mar 16 2006, 05:44 AM
While we're on the topic, the S is also my first manual car--I've always wondered if it is ok to give it a little throttle (about 1500rpm), then let off of the clutch, as opposed to letting off of the clutch until reaching the slack point, then applying throttle.
slightly off topic but i was taught that its bad to take 1st up to high rpms a lot since thats the one gear that is engaged in the most. since you always use it, more wear is put on it. so by avoiding revving too high in first, you can preserve the clutch a bit longer. true or not?
Just wanted to toss in my 2 cents, but I taught my son how to use a stick shift a few years ago and I noticed that he tended to use his hip joint to lift and depress the clutch. I think that when you get more of a feel for the clutch, you can also learn to use your ankle joint to lighten/increase pressure on the clutch pedal. This may help improve your touch when you are trying to get the car into motion from a standstill.
The most difficult manoveur when learning manual tranmission is parallel parking on a steep hill. I was living in San Francisco when I got my first manual. I still remember the bumper scars and burnt clutch odor as if it were yesterday.
I knew what to do, but it took alot of practice to master the technique.
Originally Posted by mooshy_sushi,Mar 16 2006, 10:07 PM
i do that from time to time for the same reason mentioned earlier regarding faster starts off a stop.
You could, from a stop, rev the engine and dump(very quickly engage) the clutch and let the tires do the slipping. Your clutch will love you but the rest of your drive train will want a divorce.
I have taught several people using the "catch point" method to get the feel of the clutch -- level gorund, no gas, finess the clutch so that the rpm's just begin to drop, then push it in. Practice this drill until this is an automatic (no pun) repsonse. ONce you get this, then the rpm's necessary to start will just follow how fast you want to launch.
