Need further help with abs fault diagnosis
Old Feb 27, 2025 | 06:37 PM
Niklodpd's Avatar
Default Need further help with abs fault diagnosis
Hello guys. As the title states I cannot figure out how to get my abs fixed. I cleared the dtcs and 81 came back after a drive indicating faulty abs control module. I replaced the unit with a known good, I now cannot perform abs reset and am getting no flashes to indicate further trouble codes.. I have voltage at the connector, continuity where the manual calls for it, and all fuses are good. Please help me. Thank you.
Old Feb 28, 2025 | 04:40 AM
Chuck S's Avatar
Knowing what car you have (some things differ depending on model year) may be helpful as well using a code reader rather than counting flashes (assuming that's what "81" means).
-- Chuck
Old Feb 28, 2025 | 09:19 AM
Niklodpd's Avatar
2003 which uses OBD1 connector, assuming I have that information correct. Diagnostic trouble codes are found by shorting the SCS and translating the code flash sequence, according to the manual
Old Feb 28, 2025 | 09:43 AM
engifineer's Avatar
OBD1? So yours is a JDM, not USDM model? I thought even on the JDM they went to OBD2 by 2003 but I am not sure. Every USDM model will be OBD2.
But, ABS codes are not read via typical OBD and are read by either a special tool or shorting the pins and reading the flashes as you stated.
So with the new module, do you have a constant ABS light on?
Old Feb 28, 2025 | 02:27 PM
Chuck S's Avatar
Note the connector shapes (this is an adapter but gives the idea).
-- Chuck
Old Feb 28, 2025 | 04:16 PM
noodels's Avatar
Will be OBD2 OBD2B was later MY
Old Mar 1, 2025 | 12:08 PM
Niklodpd's Avatar
Thanks for the clarification on the obd2 connector. Not sure why I assumed that.. Got the abs issue solved, ended up being a broken wire. Thanks everyone for the input
Timi
Sep 6, 2012 05:30 AM
quickshifting
20
Dec 30, 2008 01:38 PM
kentarou
Sep 27, 2006 08:18 PM
jules2k
May 28, 2006 08:06 AM
1a-race
Sep 25, 2003 05:38 AM
