Need help
Old Jan 26, 2025 | 05:52 PM
carTor's Avatar
Default Need help
Hi guys, having a little issue with my Honda is 2000 with the windows passenger side window will not go up or down but disconnected it took door panel off and was able to move window up and down with a drill battery so I know the motor is good Main problem I see is my two fuses 20 amp. The legs look burnt so not too sure if there’s a short on wiring light pro my switches I have power on some areas, but not all of them not too sure how to figure out if I have bad ground bad power or just bad switches
Old Jan 27, 2025 | 03:57 AM
NH_s2k_Guy's Avatar
I know this may sound silly but check the switch on the driver's door, make sure it's switched to on.
I've had my car 20 years and done this many times.
Old Jan 28, 2025 | 04:46 AM
carTor's Avatar
LOL it’s not a silly I thought the something but no it’s at the on position
Old Jan 28, 2025 | 05:51 PM
JBamin's Avatar
if the drivers side switch fails the pass side will not work. I have seen people get the drivers window to operate with a bad switch on the drivers side but no luck for the passenger side.
Old Jan 28, 2025 | 07:36 PM
windhund116's Avatar
I'd run a continuity test with a volt-ohm meter to check the fuses and the switch.
blink962
Jul 19, 2020 12:14 PM
Sameer
May 21, 2017 03:11 AM
Ryan_
Mar 29, 2017 08:54 AM
AndrewShaffer
Aug 22, 2010 02:44 PM
Russtwok
Jan 11, 2009 03:24 PM
