Need help with my top
Old Aug 17, 2010 | 07:10 PM
AndrewShaffer's Avatar
Default Need help with my top
Ya so i still cant figure out whats going on with my top and pass. window!! I am starting to get VERY irritated..Just in case you don't know whats going on here..My top and pass. window wont go down..But my driver side does..Checked all fuses they are all good..Took the door panels off to make sure all connectors were good..I am thinking maybe the power control module went bad, maybe a bad relay or a bad ground somewhere..Any ideas??
Old Aug 18, 2010 | 08:31 PM
JDMQuip's Avatar
Is the parking brake engaged? Is the Window on/off switch to 'on?'
Old Aug 19, 2010 | 02:46 PM
Yepp
Old Aug 19, 2010 | 04:30 PM
TheMuffinMan's Avatar
Have you applied power directly to the window motor to verify it moves???
Assuming it does your issue is between the switch and the door.
Assuming it doesn't your problem is the motor.
Old Aug 19, 2010 | 06:58 PM
aresk3b's Avatar
check the site for the RESET procedure for windows motors..
I read about that not long ago
Old Aug 22, 2010 | 02:44 PM
Yelp ran wires directly from the battery to the motors and they worked so ganna order new switches and see what happens.
Slowcrash_101
Jul 15, 2017 07:28 AM
SATXCFP
Aug 31, 2015 04:57 AM
paivag
Oct 28, 2010 06:46 AM
RunUrAss
22
Mar 13, 2010 04:57 AM
darkin.1
Jan 15, 2010 08:26 AM
