Need Help...Check engine light w/VAFC
Old Feb 10, 2002 | 04:44 PM
SaV's Avatar
SaV
Default Need Help...Check engine light w/VAFC
I need some help. I installed the VAFC this afternoon and the check engine light comes up. I checked all the wiring and everything is where it is supposed to be. The damn V-AFC even works. Any suggestions as to what is the problem? Thanks!
Old Feb 10, 2002 | 04:49 PM
XTC at 9K's Avatar
try resetting the ECU first. remove the Number 25 Back Up fuse (7.5a) from the under dash fuse box for 10 sec.!
Old Feb 10, 2002 | 04:51 PM
Flite's Avatar
if it comes back make sure your sensor type is 6. It will run good on some of the other sensor types but they might trip your check engine light.
Old Feb 10, 2002 | 06:01 PM
johnR's Avatar
I've had some probs with mine too. It usually does it when the rpm's hovering around 6k.
Old Feb 10, 2002 | 06:09 PM
SaV's Avatar
SaV
Thanks for the replies! I'm gonna try to redo everything one last time and if it doesn't work . . .well. . .I'm just gonna pay for install. Thanks!
Old Feb 10, 2002 | 06:11 PM
bayarea408's Avatar
have you tuned your VAFC on dyno or not yet? how does the butt meter feel after the install?
Old Feb 10, 2002 | 06:18 PM
SaV's Avatar
SaV
Haven't even driven the car yet. Once I put the car to ON the car spits "Check Engine." I tried the pre-diagnostics stuff, but the damn light just wont go away. I started the car and it idled very rough (idled at 1K, even though this was the first time I started the car in 2 days). Damn, I'm really mad.
Old Feb 10, 2002 | 07:01 PM
Flite's Avatar
go to etc. are you set at 4 cyl. throttle up sensor type 6 set for 9000 rpms?? It sounds to me like it's you sensor type setting
Old Feb 10, 2002 | 08:45 PM
SaV's Avatar
SaV
It is FIXED!!!! I would like to express my thanks to VTECnology and XTC. The problem was that I connected the VAFC's VTM signal straight to the car and not the ECU's harness (stupid me ) . Geez, I knew I shouldn't work on my car with a huge hangover . Latez!
abfod
Apr 3, 2005 08:43 PM
azn9imp
Jun 28, 2003 02:40 PM
azn9imp
Jun 28, 2003 04:36 AM
azn9imp
Jun 28, 2003 04:35 AM
Yellow Streak
Oct 23, 2002 01:45 PM
