Need some help!
Old May 16, 2003 | 02:36 PM
  #21
xviper's Avatar
Originally posted by ralper
This is a hard one.
Reminds of a "punchline" ................
These 3 nuns arrive at the Pearly Gates, see and ...................... Sorry, my bad ---- Off Topic!
[QUOTE]Originally posted by Ravenwerk
[B]Is there a chance that you could convince someone (small)
Old May 16, 2003 | 02:39 PM
  #22
Ravenwerk's Avatar
Originally posted by xviper
BUT HE'LL GET WET!!!!
Not if he coats himself with silicon emulsion first!
Old May 19, 2003 | 04:55 AM
  #23
marclw's Avatar
Update! I got into the trunk this weekend. It was totally dry behind and in the spare tire area. I took out all of the liners. Then I poured water through each of the trunk seams. I also poured water through the top's sides to see where the water drained. And guess what? The water appears to not get in through the top or any of the trunk seams. Another interesting fact. When I removed the floor liner, before I did my water testing, the felt under the flat right side of the liner was soaking wet -- the opposite side from the gas filer pipe. That side's felt was stone dry. Me thinks that the water is somehow coming up from the wheel well. Any thoughts on this? I did have the right real panel replaced after my accident last September. Just to ensure that the water at the bottom of the trunk drains, I drilled two holes through what looks like two plastic drain plugs at the bottom of the trunk. (I couldn't remove them!).
The ticking saga goes on. Now I'm thinking that it does get a bit faster with added speed. It is driving me nuts. It sounds to me that it is a bit louder in the left rear. Also, it does not disappear over 80. I still can hear it, but it's not quite as distinct. It seems to change a bit in connection with the car floating up and down. I'm totally at a loss.
Old May 19, 2003 | 06:43 AM
  #24
xviper's Avatar
[QUOTE]Originally posted by marclw
[B]Me thinks that the water is somehow coming up from the wheel well. Any thoughts on this? I did have the right real panel replaced after my accident last September.
[I]Take a garden hose and simulate water being thrown up by your tire.
Old May 20, 2003 | 05:53 AM
  #25
marclw's Avatar
I give up. I'm taking the car in tomorrow AM for service. I'm beginning to believe that it's the differential . . . . I'll let you guys know what happens. In the meantime, thanks for your help.
Marc
Old May 20, 2003 | 01:16 PM
  #26
ralper's Avatar
Marc
Marc
Good luck. Keep us posted.
Old May 22, 2003 | 11:05 AM
  #27
marclw's Avatar
I just got a call from the shop (Criswell Honda). They think that they have found it. It's the left abs sensor. Three of the teeth show contact and some corrosion. Their overnighting the part and it should be done tomorrow. The trunk leak was caused by a seam in the wheel well that was repaired after my accident. Apparently it was not sealed appropriately. The body shop, Rockville Auto Body, is standing behind its work and will pay for the costs of the Honda place finding the problem ($150). They also will buy me a new bottom trunk liner. Whew! I hope this fixes the tick. We'll find out for sure tomorrow!
Old May 22, 2003 | 12:58 PM
  #28
xviper's Avatar
Also check the ABS apparatus on that wheel.
Do I win a lollipop?
This suggests to me that your trunk seal is probably good and leads me back to the water getting in behind the trunk liner (so the soft top thing or the gas filler neck thing), then going to the lowest point (the bottom of the trunk), then wicking through the liner at the bottom.
How about 1/2 a lollipop for this one?
Old May 22, 2003 | 06:47 PM
  #29
ralper's Avatar
[QUOTE]Originally posted by xviper
[B]
Old May 23, 2003 | 06:00 AM
  #30
xviper's Avatar
[QUOTE]Originally posted by ralper
[B]Why would the ABS sensor cause the ticking?
