New Comptech Products...
I noticed these new IN STOCK items on the Comptech web site:
Header, Stainless Steel (S2000)
$989.95
Now in stock!
TIG welded stainless steel 4-1 header.
Uses a merged collector.
CARB legal
Quiet Tip Insert
$19.95
If our exhaust is just a little too
loud for you and you want to drop it a
couple db, our Quiet Tip Insert will do it.
Fits our 3.5" tips only, not the 4".
Includes drill bit & self tapping screw.
Reinforced Differential Housing (S2000)
$469.95
Developed to help retain the differential
and ring gear from getting shoved out the
back cover. Housing is sold on exchange basis.
Core charge is $370 and will be added to your order.
If you've already broken yours, this core charge will
not be refundable. Photo shows it with the
ring & pinion and differential already put back in.
Catalytic Converter Test Pipe (00-02 S2000)
$219.95
For maximum exhaust flow at the
race track.
May cause a Check Engine Light.
OFF ROAD USE ONLY.
NOT LEGAL FOR HIGHWAY USE!
High Flow Catalytic Converter (S2000)
$424.95
High flow converter bolts right in!
For those looking for a couple more
horsepower from their exhaust.
FOR OFF ROAD USE ONLY.
$989.95
Now in stock!
CARB legal
Quiet Tip Insert
$19.95
$469.95
$219.95
race track.
OFF ROAD USE ONLY.
$424.95
Sweet.
Hey Wes...is the "reinforced differential housing" what you have been waiting for? I remember you saying that the diff. housing being the weakest link.
What's a core charge? Is that the price of their product if you send in your stock diff. housing?
Thanks!
Thanks!
I called them when I read that. Turns out the "reinforced differential housing" is just the billet steel bearing caps with longer bolts...exactly what I bought from them 6 months ago. It's just now an official product.
The core charge means that they'll charge you for the new differential housing They'll ship the whole diff housing to you, then you can return the old housing and get the core charge refunded.
Originally posted by Phantom
So with the upgrade...is the diff. assembly still too weak to do 6k launches with a supercharger?
What else needs to be upgraded?
Comptech's CAI is now listed to be available in February for the S2000.
http://shop.innercite.com/comptech/new.html
TougeHorseman
35
Jul 4, 2012 12:35 AM
