New engine to react better to mods?
Old Sep 21, 2003 | 03:22 PM
RoBD305's Avatar
Default New engine to react better to mods?
Any idea if this new 2.2 liter engine will react better to bolt on mods since hp remained the same yet engine is larger. The 2 liter F20C showed minimal gains for intake and exhaust. Will real gains be acheived with theis new motor?
Old Sep 21, 2003 | 03:32 PM
RazorV3's Avatar
i doubt it since its still a traditional dohc vtec motor. if it was IVTEC, it would be a different story.
Old Sep 21, 2003 | 03:33 PM
SpeedxRacer's Avatar
The added .2 displacement should help the motor respond better to mods but dont expect huge gains.
Old Sep 21, 2003 | 03:40 PM
YOD88's Avatar
well thats still good right? it kinda evens out, mods will get more response than hp gains, imo its still good, a nice trade off if there are no hp gains. after all its still a s2000 which is still very good even w/out engine mods.
Old Sep 21, 2003 | 04:28 PM
Uncle Fester's Avatar
[QUOTE]Originally posted by RazorV3
Old Sep 21, 2003 | 04:35 PM
summas2k's Avatar
I thought I read the compression ratio went up. If so, doesn't that make substantial power mods (ie, FI) more diffiult to do?
As it is, you can't get much more than 5-6 lbs of boost with an S/C on the F20C.
Old Sep 21, 2003 | 11:16 PM
Quik S2K's Avatar
Yes, if they raised the compression it would hinder the SC or Turbo. Those are best with a lower compression motor to get more boost out of them. Most likely you will be able to run about 5 psi. Now with a 8-9 compression engine, you can run about 12 psi or more, depending on the internals.
Now there are different mods that can be done, but with the S as it is, it is already squeezed plenty to get max hp out of.
Urge
Feb 28, 2006 05:55 AM
Officer_Honda
Aug 7, 2003 03:46 PM
Billclintn
May 13, 2003 01:45 PM
ElTianti
Jul 16, 2001 03:02 PM
