New Twist
Old Jan 11, 2002 | 07:44 AM
Lawdog's Avatar
Default New Twist
I know we talked my recent low speed spin to death, but I just got a call from my body shop to come get the car. He said they found that the right front tire was mounted backwards on the wheel!!!! What effect would that have on handling? Could it have been a significant factor in the accident? I never noticed this when I got the car back after having the new tires mounted, but I will be sure to check everything from now on.
Old Jan 11, 2002 | 08:04 AM
gregstevens's Avatar
Banned
Wow...I haven't heard of THAT happening before!
But it shouldn't cause any issues with handling...only if you were in the rain as that is what the channels are designed for.
What stupidity...! I would also suggest that you car go no where near whoever put the tires on!
Old Jan 11, 2002 | 08:53 AM
Tox's Avatar
Tox
Originally posted by gregstevens
...But it shouldn't cause any issues with handling...only if you were in the rain as that is what the channels are designed for...
I guess a backwards tire would actually pump water from the edge of the tread to the middle, and maybe would hydroplane even more easily than a slick!
Old Jan 11, 2002 | 09:21 AM
xviper's Avatar
I've been told by tire guys that radial tires and in particular, uni-directional ones, should not be used on the other side of the car (or "backwards" in this case) as they get "used" to rolling mainly in one direction. If reversed, rolling resistance and resistance to lateral forces change and may cause "unbalanced and inappropriate" handling characteristics. And this isn't even talking about water issues.
Old Jan 11, 2002 | 03:22 PM
animeS2K's Avatar
That is a bad thing. Where did you have tires put on? I'm sure your insurance took care of this for you, but it will be listed as an "at fault accident" and make your rates go up. Not good. I would look into this further.
- Chris
Old Jan 11, 2002 | 03:27 PM
bayarea408's Avatar
very bad, it will really mess up the tracktion of the car... the tire is not ment to be running in opposite directions and might have an adverse effect...
Old Jan 11, 2002 | 03:33 PM
PLYRS 3's Avatar
i had a highly modified mustang 6-7 years ago that had one unidirectional front tire mounted "backwards" - the right one.
the result was that when loading the right front corner (taking a left turn), the right front tire had NO grip.
i actually drove around like that for a few days until i noticed it when armor-all-ing the tires after a car wash.
you would never think the discrepency in handling would be so obvious, but it is.
regards.
Old Jan 11, 2002 | 03:51 PM
cdelena's Avatar
According to the Bridgestone staff that we talked to on this very question.. it will make no difference in the dry and the tire does not care. It will screw up performance in the wet because water is not channeled away properly so I imagine that tire would be prone to hydroplane easily.
As I recall your spin was the rear coming out in a lift throttle situation. My guess is that this tire had nothing to do with it.
Old Jan 11, 2002 | 06:32 PM
Takashi KazuMori's Avatar
Directional tyre mounted on the wrong side ... Now, that's a first.
Old Jan 11, 2002 | 07:03 PM
Banned
cedelena summed it up.
Everyone would be running on slicks were it not for rain...so tires have channels to direct water as the tires pass over and through the water...you still maintain the same contact patch in the dry whether the tire is on the right way or not.
Emil St-Hilaire
Oct 15, 2018 08:48 AM
XJS2K
Jun 28, 2014 12:57 PM
SilverS2KAZ
Apr 16, 2004 04:09 PM
SilverS2KAZ
Jul 17, 2003 04:24 PM
Relson
Sep 29, 2001 07:53 PM
