is it normal for the engine to move/shift
Old Oct 3, 2007 | 12:11 PM
boofer's Avatar
Default is it normal for the engine to move/shift
also, if i'm at a stop light and i rev it while the transmission is in neutral, i can feel the engine move. is this normal? i had my friend look at the engine with the hood popped and it definitely would move to the side if i revved it.
as far as i know, this didn't happen in my previous 4 cars.
Old Oct 3, 2007 | 12:13 PM
jlstyle82's Avatar
Buy my ETD
It will lessen the vibration.
Shoot me a PM if you want to buy.
It's NRG ETD and I'll let it go $90+shipping.
Old Oct 3, 2007 | 12:20 PM
SSSnakeSSS's Avatar
All motors are set on large rubber gaskets allowing them to move slightly when you rev the engine. Almost all cars I have ever owned basically rocked a bit when reved, but never moved off their bolts.
Old Oct 3, 2007 | 12:23 PM
boofer's Avatar
Originally Posted by jlstyle82,Oct 3 2007, 12:13 PM
Buy my ETD
i have no clue what an ETD is (engine torque damper or something?) but it's not that i get excessive vibration through to the cabin....what exactly does an ETD do?
Old Oct 3, 2007 | 12:32 PM
jlstyle82's Avatar
It is a device that suck up bit of engine movement.
Car will acel. little less abrubtly with it on.
Do some search about it and let me know if you want it, I have it uninstalled and just sitting around in my garage.
Old Oct 3, 2007 | 12:35 PM
boofer's Avatar
why did you uninstall it?
Old Oct 3, 2007 | 12:42 PM
Boofster's Avatar
Here's what it looks like (little orange thing):
Old Oct 3, 2007 | 01:53 PM
littlerocket777's Avatar
Your engine should not be moving as much as you describe. I mean if you can feel it, it's too much, unless you're really sensitive. Check the engine mounts and bolts. I had a nut come off my CRX before and it shook. Wow.
Old Oct 3, 2007 | 02:43 PM
S2KPUDDYDAD's Avatar
Pretty
Here is mine
Old Oct 3, 2007 | 03:23 PM
Feezy's Avatar
Which ETD is that? Looks like the J's color but i was under the impression that the J's ones mount to the shock tower...
