is this normal for a s2000 top?
Originally Posted by G,Aug 21 2009, 10:18 PM
His is an 07, that seams very early for the straps to be worn out. I just replaced the originals on my 03 in the spring.
The top is def too high. when you look in your rear view mirror the "handle" should be below the trunk level.
I've just replaced mine with Modifry's straps also.
Very easy fix.
It took me about 10 min. to change em out.
Be careful not to cut the top though.
I used a letter opener to cut the old ones out.
Very easy fix.
Originally Posted by evil s2k,Aug 21 2009, 06:30 PM
the straps were worn on my 07 also. Honda replaced them since I bought it used and it wasnt my fault, problem went away.
Its caused by having the top down and not using the tonneau cover as the sun dries out the elastic and makes them lose their elasticity.
I am lucky I guess.
Originally Posted by tekstar,Aug 21 2009, 05:39 PM
when you sit in the car with the top up, the bar straight above your head is not folding down flat all the way. push it down as you lower your top. it is the bar held on by the elastic straps.
Fold the top down half way and then stop. You'll see one bar that will move, the others are fixed. Push the bar that will move toward the back as far as it will go while continuing to roll the top down and it should fold perfectly. Some people replace the elastic straps but even that won't guarantee that the bar will fold all the way back like it should. it takes no extra time to "assist" it once you've done it once or twice.
