OBD 2 connector...
Old Jun 21, 2001 | 08:21 PM
nibble's Avatar
I received mine as well.. But as a first timer, I'm scratching my head to figure out what to do... If someone could explain or some picture would be nice. TIA.
cheers,
Old Jun 21, 2001 | 11:47 PM
bentrim's Avatar
Got mine today, havent had a chance to play with it. Probably will in the morning.
Old Jun 22, 2001 | 12:28 AM
le car's Avatar
I thought this was going to be about Old Dirty Bastard ...
Old Jun 22, 2001 | 05:38 AM
shingles's Avatar
Ok here's what you need to do:
1) make sure the serial port on your laptop/machine is enabled.
2) get the email that Alex sent you, there's a reg code on there.
3) plug one end into car, the other onto laptop
4) download software, the top one, the one that's .3 megs, extract into folder of choice, and run.
5) hit the connect button
6) you will not be able to connect as you will get an error, after error, click through a couple of screens you get the "ID" page. Enter in the id in the email. THIS IS IMPORTANT, eitherwise the software won't work.
7) connect again...
8) click away and look away.
There's a help file that talks a little about each screen.
What I find interesting about this tool is that I would plug it up and drive at various speeds to record the info. One thing that I am very interested in is the intake air temp... it would appear that unless you are going above 35mph, the IAT will not start to come down.
-Shing
Old Jun 22, 2001 | 06:02 AM
nibble's Avatar
Thanks, shing. I'll try that later on today.
cheers,
Old Jun 24, 2001 | 02:46 PM
K.C.'s Avatar
Shing,
how many pins come with the OBD 2 connector?
i just got a portable scan tool for honda but not sure can be used on s2000.
thanks!
Old Jun 24, 2001 | 03:03 PM
cdelena's Avatar
I got mine last week but just got a chance to try it.. without success. I get a 'busy signal' after initialization. Any idea what I have done wrong?
I am using a PC I am not familiar with.. is this a symptom of a bad port?
Old Jun 24, 2001 | 03:11 PM
Schatten's Avatar
could be chris, make sure its enabled in the bios. depending on the manufacturer, some do not enable it by default. so check the bios settings.
mine works fine, it says busy, but then after four seconds, it connects - which appears to be 'normal'.
Old Jun 24, 2001 | 03:13 PM
demonderrick's Avatar
does that mean if I have no laptop, I can't read it?? huh?? cuz I don't have one... but I don't wanna buy one laptop just because of it! I already got 3 computers..!!
Old Jun 24, 2001 | 03:15 PM
[QUOTE]Originally posted by shingles
[B]Ok here's what you need to do:
