Observation on 2.2L vs 2.0L
Old Sep 26, 2003 | 02:14 PM
FCGuy's Avatar
Default Observation on 2.2L vs 2.0L
...Well, of a math/engineering perspective...
When I see "same hp, somewhat higher torque, somewhat lower redline", I think "gear ratio". So, taking the published crank torque curves for the 2.2L and 2.0L (training manual and SAE paper, respectively), I tried to fit them to each other by varying gear ratio. Sure enough, if I take the 2.0L curve and multiply by the actual displacement ratios (1.08), the curves overlap quite nicely. They actually fit best to a "gear ratio" of 1.06-1.07. Worst off by ~5 lb-ft, normally +/-2.
Basically, if someone put a box around a 2.0L with an added gear ratio of 1.07, it would mimic the 2.2L almost perfectly. You'd read near the same torque, same hp, same rpm. And I venture it would perform near identically!
Given Honda already increased the secondary ratio from 1.16 to 1.208, I'd say the '04 would behave just about like an '03 with 4.10*1.07*(1.208/1.16)=4.57 final ratio. Which is currently the subject of another post. So, to get a good idea of its real-world performance, look to posted results of 4.44 and 4.77 ratio'd cars.
Old Sep 26, 2003 | 02:30 PM
smakbiam's Avatar
very cool observation
Old Sep 26, 2003 | 02:42 PM
mashoutposse's Avatar
You're right. Unfortunately, pre-'04 owners will still have to deal with the shorter sixth gear (and the resulting bump in RPMs at cruising speeds)...
Old Sep 26, 2003 | 03:56 PM
3ngin33r1's Avatar
Is this one of those times that they said algebra would save my life?
Old Oct 8, 2003 | 04:48 PM
Luis's Avatar
[QUOTE]Originally posted by FCGuy
Old Oct 8, 2003 | 05:33 PM
Chadwick's Avatar
LMFFAO
Old Oct 8, 2003 | 06:27 PM
rai's Avatar
rai
OK Mr. Math, what about the larger wheels on the 04?
Old Oct 8, 2003 | 06:31 PM
FCGuy's Avatar
What about them? They have the same outer tire diameter, within a % based on nominal specs. Or are you referring to added weight? Virtually no effect.
Old Oct 8, 2003 | 08:30 PM
Elistan's Avatar
FCGuy, thank you for stating in such a clear manner the root of this whole situation.
(FWIW, my personal opinion is that it's a shame what Honda did. Sigh.)
Old Oct 8, 2003 | 08:38 PM
ttb's Avatar
ttb
gearing gearing gearing
torque is meaningless
