Odd smell under hard acceleration
Old Jul 5, 2006 | 05:46 PM
S2k Aloha's Avatar
Default Odd smell under hard acceleration
I don't know if it's normal or not, but I've noticed under hard acceleration (e.g. getting onto highway) I notice an odd smell. I can't pinpoint it exactly but it smells somewhat like hot metal, hot rubber, etc. Has anyone else experienced this?
It's an 06 with about 4500 miles. Properly broken in. The engine is plenty warmed up when doing this too. Thanks for the help!!
Old Jul 5, 2006 | 06:03 PM
bizlipkick's Avatar
vtec burns oil. i have had the same smell in every vtec equipped car i have owned.
archtop's Avatar
Clutch!
Old Jul 5, 2006 | 06:04 PM
xviper's Avatar
Are you sure it's not just you shittin' yer pants?
Maybe your clutch is slipping. Are you using it during this time? You may be dropping the clutch too fast at too high an rpm when you shift. Or are you riding the clutch?
Old Jul 5, 2006 | 06:18 PM
S2k Aloha's Avatar
Nope...nothing with the clutch. This happens when I'm already rolling...not slipping/dropping the clutch. Does it really burn a bit of oil in VTEC? If so that would sound reasonable as far as the smell is concerned. Is that normal though if that's the case?
Old Jul 5, 2006 | 07:01 PM
xviper's Avatar
AP1's are known to use oil when revving up high. AP2s are known to have much less oil use. However, this kind of oil use is not generally detectable by smell. Maybe since your car is still new, you are still burning off some protective coatings around the engine and it's not till you run it hard that it gets hot enough to burn this stuff off. Quite frankly, without experiencing what you see and smell, it's tough to figure out if anything is wrong.
05berlinas2k
Mar 9, 2010 05:30 AM
jdmgpw04
Jun 18, 2007 10:04 PM
B.Money
Mar 18, 2007 09:19 PM
s2000james
Sep 25, 2002 02:26 AM
S2Kbure
Mar 19, 2002 08:18 AM
