odd soft top leak
Old Sep 7, 2008 | 09:20 AM
vtec9's Avatar
Default odd soft top leak
I have a strange leak.. Water is collecting in the frame above the drivers window. It will leak out when the car moves, or when I open the top.. yesterday during the tropical storm I went to drive somewhere, and my left arm got completely soaked from a gallon of water while backing out of the driveway. Water is coming from the frame where circled in the picture. That part of the frame is hollow, but I don't know how water is getting in there. I see no holes in the vinyl. I suppose it must be seeping up between the top and the frame, but the gaskets look good, and I see no holes.
any thoughts?
Old Sep 8, 2008 | 03:27 AM
jguerdat's Avatar
Not that it helps but I've had this since the car was nearly new. Never found the problem. Tried to add some black RTV near the windshield gasket with no difference. I'm now wondering if it's entering at the joint you show in your picture rather than from the front.
Old Sep 8, 2008 | 04:17 AM
ian05s2k's Avatar
You may be in need to foms shin etsu grease, it will plump the rubber areas around there and may prevent water from getting in. It is at least worth a trey if you havent done it in a while. On top of that its really cheep as well. You can get it from Your local Honda dealer for a few dollars. Good luck figuring it out man.
-Ian
Old Sep 8, 2008 | 04:53 AM
vtec9's Avatar
I have a tube, but rarely use it.. I did yesterday though all around that area, so we'll see.
Jpee
Jul 20, 2018 01:18 PM
gregasorous
Sep 6, 2017 02:16 PM
jean-roch
Jul 2, 2017 05:31 AM
turtleesss
Feb 22, 2017 09:27 AM
fto222
May 22, 2006 11:26 PM
