oil
Old Jun 10, 2001 | 03:57 PM
Eze8199's Avatar
Default oil
What is the best oil to use for the s2k? Also, does mobil make an oil that I can use for the s2000? Thanks
Old Jun 10, 2001 | 04:00 PM
Utah S2K's Avatar
Mobil 1 Synthetic is the drug of choice here but only after 5,000 break in miles.
Old Jun 10, 2001 | 04:13 PM
Eze8199's Avatar
i only have about 2300 miles on my car
Old Jun 10, 2001 | 05:15 PM
Eze8199's Avatar
Old Jun 10, 2001 | 05:40 PM
cdelena's Avatar
Originally posted by Eze8199
Use any premium 10w30 oil for now and when you feel it is broken in (maybe 6K - 10K miles) you can look at using a synthetic.
Old Jun 10, 2001 | 11:52 PM
nvmys2k's Avatar
I've been using Mobil 1 Synthetic oil since 7500 miles. I'm pretty happy with it...
Old Jun 12, 2001 | 02:19 PM
kmohamme's Avatar
Thanks Guys... I was concerned about my oil as well since I only just checked it since I bought the car. It has approx. 2200 miles on it. The tech at Honda said I should use 10w30.
later on maybe from 6000 miles I will start to use the Full Synthetic. Or just change my oil every 1500 - 1700 miles if I use regular oil.
Right now I am sure it needs some so I'll add non synthetic just to top it up. He also said that if the oil light had lit up, its too late, the engine had already been damaged which will show in it's later years. He said that the engine runs at 15psi or something and when the oil light is on It's actually running at 8psi or so.
Basically, check your engine oil regularly and you'll be fine. My suggestion is to have a few liters in your trunk.
Peace.
my2k2s2000
Jul 19, 2003 09:05 PM
Lunacy
Dec 18, 2002 06:34 PM
LELANDRO
Nov 18, 2002 06:03 PM
JimmyB
Jul 24, 2002 08:29 PM
BlueS2000Boy
Jun 2, 2002 04:16 PM
