which oil?
Old May 31, 2004 | 12:20 AM
emrillive's Avatar
Default which oil?
i am commming up on my first oil change and i am planning to wait till 10,00 miles before getting mobil 1 10w30. so i was wondering what i should get for now?
oem honda oil?
castrol?
Old May 31, 2004 | 12:55 AM
jyeung528's Avatar
i liked castrol gtx.
use amsoil or redline, ditch the mobil 1.
Old May 31, 2004 | 07:52 AM
TunedS2000's Avatar
I was planning on switching to mobil 1... Is this a good idea?
Old May 31, 2004 | 08:37 AM
VTECorona's Avatar
Mobil1 burns a bit more then regular dino oil, the protection is a bit better w mobil1 though. Buy an extra quart to add within your 3-month intervals, VTEC motors usually burn about a quart between changes, depending how often it sees VTEC of course.
Old May 31, 2004 | 09:30 AM
honda606's Avatar
[QUOTE]Originally posted by emrillive
Old May 31, 2004 | 09:31 AM
honda606's Avatar
Read your owner's manual immediately.
You shouldn't even be considering the switch to synthetic until at least 7,500 miles. I waited until 10k.
Old May 31, 2004 | 09:34 AM
TunedS2000's Avatar
its to late for that, I switched to penzoil synthetic at 3,750 miles because my dealer did it. I have not had any problems and I have just been over 6,000 miles with no oil consumption. I am not worried.
Old May 31, 2004 | 10:22 AM
emrillive's Avatar
can you take the filter off by just using your hands?
also can anyone reccomened some good ramps with a extension so you can come up on them even with a low profile car?
Old May 31, 2004 | 11:52 AM
jyeung528's Avatar
depends how strong ur forearms are...if strong, then yes.
I need to slip a filter wrench from the top and loosen it before using my hands.
however, i tighten it with my hands.
Old May 31, 2004 | 12:09 PM
Asura's Avatar
First filter change? It will be on very tight from the factory. My recommendation is to stick a screwdriver through it to get it off. Otherwise good luck, I hope your forearms are like Popeye's.
Regarding oil choices...read the oil journals in UTH. Road Rage has taken a lot of time to wriite some very informative commentaries on oil. Unless of course, you have no interest in gaining any knowledge and would just like a opinion on what is best.
