Oil level Down
Old Nov 6, 2003 | 07:41 AM
AustinS2k2003's Avatar
Default Oil level Down
I got an oil change 1K miles ago. Checked my oil this morning and I am down to one tick over the low line on the dipstick. I am down probably 2-3 qts and am going to put more in but this is the first time my S has burned oil like this. Anyone else experiance this? Should I be concerned?
Old Nov 6, 2003 | 07:51 AM
AOK's Avatar
AOK
Sounds like the place that did the oil change did not properly check the oil level. heard other's complain about this problem thats why I do my own oil changes or have the dealer change it.
Old Nov 6, 2003 | 07:59 AM
xviper's Avatar
If you are just a tick over the "low" line, DO NOT put in 2-3 qts. The whole area between the "Low" and "full" lines represents 1 quart only. If you put in 3 qts, you will be very sorry.
Depending on how you drive (frequency of VTEC) and how many miles are on your car, 1 qt. in 1000 miles is not unusual.
Old Nov 6, 2003 | 08:14 AM
SonTon2003's Avatar
1qt, don't overfill
Old Nov 6, 2003 | 04:48 PM
Road Rage's Avatar
1qt! tops.
This usually happens when they add the oil, and do not fire it up, then check again - they forget that the filter will pull a fair amount of oil. Another reason to DIY. A good shop always starts the car to check for leaks from poor install or defective gasket. Then wait 5 minutes, check level again.
Old Nov 8, 2003 | 12:49 PM
F20C_S2k's Avatar
i was just wondering, how much oil does our engine take?? in liters?
Old Nov 8, 2003 | 12:56 PM
SpeedxRacer's Avatar
I believe our manual says the S takes 5 quarts, I know it cant be more than 5 but its around there.
Old Nov 8, 2003 | 02:41 PM
03BerlinaS2K's Avatar
At 1,500 miles I was right at the "L" mark. I put in 1 quart of Mobil One and was just under the "F" mark. I'll check it again at 2,000
anthonylan
Dec 17, 2012 05:23 AM
SebRedAP1
Sep 28, 2009 02:35 PM
Spami
Inland Empire S2000 Owners
Nov 25, 2005 02:43 PM
rikhemi
Mar 1, 2005 06:14 PM
GundamZ
Aug 7, 2002 12:17 AM
