ongoing hardtop problems
I had my hardtop installed by Hardtop guy (Jeff from Ganley Honda, a board sponsor) and to date, I've had absolutely no problems with squeeks or wind noise. The only squeeks in my car are when the seats are all the way back and rub against the rear and roll bars....
The install was $150 by Jeff...
Good luck! Love my hardtop...hope you feel the same about yours soon enough!
Yes i am taliking about the rear where it comes into contact with the car. Apply a heavy coat of shin etsu on the rubber part attached to the hardtop massage in. Wait a little while for the rubber to absorb it. Then apply a second coat. I have no squaeks or creaks after I did this. Nice and quite! Shinetsu is the stuff works great! Much bettter than any silicon type spray!
Originally posted by ItalianBucwheat
Nice and quite! Shinetsu is the stuff works great! Much better than any silicon type spray!
Just a note about having your dealer adjusting your top. As long as it is a factory part and the car is still under warranty it is free of charge wether your dealer installed it or not. Any dealer can warranty the service not just the dealer you purchased from. You can call customer relations at 800-999-5901 if your having problems with your dealer.
Originally posted by SanMarinoCpe
...As long as it is a factory part and the car is still under warranty it is free of charge wether your dealer installed it or not. Any dealer can warranty the service not just the dealer you purchased from. You can call customer relations at 800-999-5901 if your having problems with your dealer.
to make matters worse, when i removed it i was NOT able to get it back on again. the two rear pins are approximately 3/4" out of position... far too much to simply "force" in. unfortunately i took it off at my brother's place in l.a., needed to leave at approximately 4 in the morning to make it to work in s.f., and he didn't have a socket wrench. so, i left the ($)#*$)(#*$)(# top in santa monica.
next time i go down there, i'm bringing the shin etsu and my tools, and hopefully i can resolve it.
one thing is certain : with all the BS SF Honda has given me, i am not taking the car back there.
I'm under the impression that a lot of guys are loosening all FIVE adjustment bolts on each side when they do the install.
THIS IS A BIGMISTAKE!!!
ONLY loosen the TWO bolts at the bottom to adjust the fitment during install. If you loosen all the bolts you'll never get proper fitment.
If you installed your top and loosened all the bolts, I suggest you have a dealer try to make adjustments.
Good luck.
Good luck.
well, i used the instructions. you need to loosen the three bolts on each side in order to move the top up and down and forward and back. the two bolts you speak of move the top left and right.
i really doubt the instructions are TOTALLY mistaken about the method of adjusting the top.... but we'll see when i get a crack at it again.
Nfsryder
Aug 7, 2018 01:07 PM
yellow2000
Jan 28, 2002 02:08 PM
