Painted headlights
Old Apr 18, 2006 | 06:43 PM
CHUCKLIDDELL101's Avatar
Default Painted headlights
Wuts up everbody. I did a search for this topic but every thing was light 3 years old and the links and pics didn't work. I want to paint the housing of my headlights suzuka blue. Is there a kit or do I take it to a body shop? I heard it needs to be high heat resistant paint. Do they make that kind of paint in the same color? Thx in advance
Old Apr 18, 2006 | 08:15 PM
nightcrawler7188's Avatar
what do you mean by painting the headlight housing???
do you mean the grey plastic that surrounds the bulbs, or the actual clear plastic part that covers it all?
Old Apr 18, 2006 | 08:31 PM
04RioS2k's Avatar
I'm pretty sure he means the inside that surrounds the bulb...
Old Apr 18, 2006 | 09:23 PM
Kodokan_4's Avatar
You need to bake them in an oven to melt the seals, then split the housings.
Remove and spray the inserts with high temp paint and clear.
If you're going to change the diffusers, do it while you have the casings open.
Then do the tail lights.
-Pete
Old Apr 18, 2006 | 09:25 PM
dyhppy's Avatar
done it before and it's a rough ride. good luck.
Old Apr 18, 2006 | 09:28 PM
darkfx's Avatar
I have it done.. not fun, but worth it
Old Apr 18, 2006 | 09:37 PM
S2K:-)'s Avatar
Anyone got some good pics of an NFR one?
Old Apr 18, 2006 | 09:39 PM
Kodokan_4's Avatar
Look for pics of Nibble's old ride.
-Pete
Old Apr 18, 2006 | 10:03 PM
phishphreak1234's Avatar
did it with my old rsx-s. it sucked and took forever. make sure you let it dry overnight and seal completely, otherwise you get fumes and/or condensation inside the lense
Old Apr 19, 2006 | 04:08 AM
ruexp67's Avatar
Let's be clear. Getting the headlights open is the tricky part. There are detailed instructions on how to replace the diffusers at http://www.ricks2k.com
Once you have the headlight open, painting the housing is pretty easy. (Well, I already had the car in the body shop so I took apart the light and gave THEM the housing to paint, but for a PAINTER, it's pretty easy. )
