Passed Smog with an '06 engine in my AP1
Old Feb 26, 2013 | 12:28 PM
AP1Theory's Avatar
Default Passed Smog with an '06 engine in my AP1
I'm just writing this up for information for people that are in a similar situation as I was in. I was stupid and didn't do any research before buying a low mileage clean but dirt cheap '06 engine to replace my blown engine in my AP1. The problem was that the '06+ engines do not have the holes drilled in the cylinder head for the EGR port to use the air injection pump, so I was stressing over the smog for quite some time. When it was time for me to smog, all I did was install a Izze engineering air pump simulator and connected every component associated with the air pump onto the engine to make it appear like it's actually working. I also unplugged the air pump relay, because the air pump is loud as hell when it's trying to blow air into a closed tube. I took it in to smog and it passed.
Has anyone passed smog with the air pump simulator installed and air pump and it's components taken out?
Old Feb 26, 2013 | 03:18 PM
thomsbrain's Avatar
You should include your state/county as tests and requirements vary widely.
Old Feb 26, 2013 | 03:58 PM
AP1Theory's Avatar
Sacramento, California.
Old Feb 26, 2013 | 04:07 PM
JackS's Avatar
My understanding is that these cars will usually pass emissions even with changes but can still fail on visuals if changes are noted. Congratulations especially in Calif.
kolourredd
Sep 5, 2014 08:42 AM
Beyond_Redline
Jul 15, 2012 11:22 AM
gravitykills
Aug 28, 2008 06:34 PM
chandler_hall
Nov 21, 2005 11:53 AM
blacks2k
Jul 5, 2003 09:45 AM
