Passenger door wont open, from inside and outside!
Old Jan 21, 2007 | 01:12 AM
RCHB's Avatar
Default Passenger door wont open, from inside and outside!
My 00 passenger side door wont budge . It did in the morning once, but sounded like something broke off or came loose while i pulled the exterior handle open. After i shut it(i was at work, i had to) it wouldnt open again. The interior handle worked once after. After that nothing from either.
Is it possible to take the door panel off while the door is shut?
i really want to open it up to see if i can fix it before i take it to the dealer.
or is there any other way of getting my door open?
im driving my no so comfortable 91 mr2 now and i already want the s2000 back to normal.
Old Jan 21, 2007 | 07:28 AM
S2KBG's Avatar
try to open it w/ the key from the outside or check your door lock on drivers side door....maybe u set it on unintentionally.
Old Jan 21, 2007 | 05:53 PM
RCHB's Avatar
tried it. still nothing...
can i take my door panel off with the door shut?
Old Jan 21, 2007 | 06:03 PM
spa01s2k's Avatar
There is no way to take the door panel off without the door being open. There is a screw that holds the panel on that is between the dash and door panel.
As far as your problem goes, I can't help . I've never come across something like this.
Old Jan 21, 2007 | 06:11 PM
s2kAtTracks's Avatar
uhh, I am not aware of anyway to take the door panel off with the door shut.
Like spa01s2k said, There is that one screw that is now not accessible.
Old Jan 21, 2007 | 06:30 PM
JackS's Avatar
Take your car to a locksmith and let them open it for you. There's a tool that slips between the door an window that they use to trip the lock. Expect this would cost $30-50 bucks. Since the lock is electric , might have to disconnect the battery, reset CEL's ect.
Or... look at a picture of the mechanism and using a bent coat hanger, try to do it yourself first. You might be able to save some money with a successful "jimmie"
Old Jan 21, 2007 | 07:42 PM
i2ichal2d's Avatar
the lock isnt the problem i assume? he can unlock it, but its the opening mechanism itself that crapped out. GL!!
Old Jan 21, 2007 | 10:17 PM
RCHB's Avatar
[QUOTE=i2ichal2d,Jan 21 2007, 08:42 PM]the lock isnt the problem i assume? he can unlock it, but its the opening mechanism itself that crapped out.
Old Feb 6, 2011 | 02:27 PM
EsTooTouseng's Avatar
i am having this same problem. but with BOTH doors. i cant open any door inside or out. u can hear it try to unlock but it just wont. when i hit the unlock button on either the alarm remote or the original key fob the light inside turns on then shuts off immedietly. has anyone had this problem
Bigchief
Apr 13, 2014 07:32 AM
lunar_s2k
Sep 8, 2013 09:04 AM
NA1NSXR
Apr 8, 2011 07:25 AM
s2000 gib
Jan 3, 2011 04:15 AM
s2konroids
Jun 1, 2009 03:18 AM
