Polishing the intake manifold
Old Nov 14, 2007 | 01:59 PM
ShocK's Avatar
Default Polishing the intake manifold
Well I started polishing my intake manifold and its taking forever. I'm using a die grinder with some sanding wheels, they are a combination of 2"x1" peices of sand paper and between them are pieces of scuff pad. So far its worked ok but I need to get between the intake runners and around the nooks of all the manifold where the vacuum lines connect. Anybody got any clue what I need? I tried hand sanding but... lol that would take a few years to finish at that pace. My dies are 1/4" shafts, I also have a dremel (1/8" shaft I believe) that I can use but I'm having trouble finding bits. If anyone has any experience doing this let me know. Thanks
Old Nov 14, 2007 | 02:02 PM
hisownhero's Avatar
Try either a Dynafile grinder or a straight grinder with cone sandpaper (I'm guessing you have a angle grinder). Hope this helps.
Old Nov 14, 2007 | 02:24 PM
ShocK's Avatar
I'm going to check and see how much its gonna cost for someone to finish it for me, I did quite a lot of work so maybe it will be cheaper to just pay someone to finish it than for me to buy more tools.... lol
Heres what I have
Heres the style bits
Old Nov 14, 2007 | 05:22 PM
daktruckie99's Avatar
I clean my engine weekly and that is the one part that isn't as clean as I'd like. I know of no easy way to clean it though without removing.
Old Nov 14, 2007 | 08:27 PM
ShocK's Avatar
Its off the car, I'm not cleaning I'm removing the casting glaciers on it and chamfering all the edges, smoothing pour spout places etc etc... heheh heres a pic of the progress.
Old Nov 14, 2007 | 08:29 PM
ShocK's Avatar
Toothbrush + gojo works awesome just to let you know
Old Nov 14, 2007 | 09:44 PM
kial007's Avatar
Check Eastwood.com, they have a ton of polishing buffs and abrasive bits. They may even have a flex shaft for your grinder to help get between the runners.
Old Nov 14, 2007 | 09:49 PM
ShocK's Avatar
anybody know if I can shave off that big square chunk hanging off the side next to the IAC valve? Looks like I can but don't wanna fubar this intake
Old Nov 14, 2007 | 09:51 PM
ShocK's Avatar
maybe one for the ole dremel might help. Dremels are such crap, barely used mine and it vibrates like an SOB.
Old Nov 15, 2007 | 07:56 AM
HankookS2K's Avatar
looks good so far! post pics afterwards too!
